1st_polo
Posts: 28 Joined: Sun Nov 09, 2008 11:21 pm
Post
by 1st_polo » Mon Nov 10, 2008 11:24 pm
Im going to take my badges off the back of my car tomoz and just leave the Volkswagen one.
Wat would be the best wat to romove them and how they held on
Cheers guys
Jordan
pip_polo
Posts: 2454 Joined: Thu Jan 04, 2007 3:20 pm
Post
by pip_polo » Mon Nov 10, 2008 11:29 pm
heat them up with hot water/hairdryer
then peel them off. or use fishing line behint badges
if your lucky it will bring most the glue off.
if not use wd40 or something to take the black glue off.
search in diy guides for it in more detail. think i did it ages ago.
Tim_GTi
Post Whore
Posts: 12289 Joined: Mon Jun 25, 2007 6:31 pm
Post
by Tim_GTi » Mon Nov 10, 2008 11:30 pm
Heating them up helps, but is not essential.
They're stuck on with sticky foam, so just cut it off with a guitar string/fishing wire.
Then use some WD40 or a cleaning product of your choice (AG intense bug remover is good) to get the residue off.
1st_polo
Post
by 1st_polo » Mon Nov 10, 2008 11:59 pm
Cheers guys that helps alot
Also is it hard to take the gear knob off so i can change it
cheers
jordan
Tim_GTi
Post Whore
Post
by Tim_GTi » Tue Nov 11, 2008 12:02 am
If it's anything like the 6n2 (pretty sure it's very close), just gently unclip all the plastic tabs aroud the edge, then flip off the metal clip on the underside.
1st_polo
Post
by 1st_polo » Tue Nov 11, 2008 12:08 am
Cand i take the Vw one off aswell or is that clipped on and would i have to get that smoothed out?
Jordan
Tim_GTi
Post Whore
Post
by Tim_GTi » Tue Nov 11, 2008 12:41 am
not sure on the 6N in terms of clips, there's an indent though, so you'd have to get that smoothed out.
vw-po-low
Posts: 929 Joined: Thu Apr 24, 2008 7:13 am
Post
by vw-po-low » Tue Nov 11, 2008 7:28 pm
The 6N has two small sections that clip into the boot as well as the glue foam. I just gave mine a tug.. all the glue stayed on the badge. Though mine is currenly super glued on now that its black.
stevan
Posts: 7 Joined: Fri Nov 07, 2008 1:27 pm
Post
by stevan » Fri Nov 14, 2008 5:36 pm
Take your time!!
