6n2 drivers door electrics updated.
poLoTDI1.4
Post by poLoTDI1.4 »
Hi everyone,
Yet another 6n2 electrics problem!
The buttons on the drivers door:
1) drivers window wouldn't go up or down
2) passengers window went down with both up and down buttons
3) doors locked with the lock button, but would not unlock
Put key into lock - locks / unlocks only that door.
But the door locks / unlocks with passenger side central locking.
So, central locking works fine. It's only the drivers door that does nothing. Will lock / unlock manually with the key, but will not effect the central locking.
Thanks in advance for your help,
Lisa.
alexperkins
Site Admin
Re: 6n2 drivers door electrics updated.
Post by alexperkins »
Check the main cable joint that goes between the door and the car itself is tight as this may have come loose which will effect connectivity.
poLoTDI1.4
Is that the sort of toothed connector? its firm to the car, i couldn't get it off. cnt get to the connections on the inside of the door through.
alexperkins
Site Admin
yes it is. It twists off only about half a turn tho
poLoTDI1.4
so i should be able to see if any wires are split / broken / disconnected inside there?
poLoTDI1.4
alexperkins wrote:yes it is. It twists off only about half a turn tho
I really can't get this off!! :oops:
i've tried loads. i guess there's no trick as such to it?!
alexperkins
Site Admin
Normally you have to use a pair of grips - its quite a difficult task to get it to move, but it could be the cause.
poLoTDI1.4
i have it moving a bit but definitely not enough for it to come off, thanks alexperkins. i will keep trying! its just so cold outside!
now the passengers window switch will just let it go down and the up button does nothing. central locking button locks but doesnt unlock. drivers door locks / unlocks from passenger side but not drivers. strange!!
alexperkins
Site Admin
Youve definately got a connectivity problem for sure. Keep trying ;)
poLoTDI1.4
ok so i still can't get this thing off, there's a chunk out of one of the teeth from using grips to twist it. it's moving about one cm and that's it!
i took out the bottom of the dash and had a look at the wiring but all seems normal. vag-com didn't pull anything up either :(
This is really getting to me! I need to find a man with more strength and no nails to give it a proper go!
alexperkins
Site Admin
Thats as far as it twists. 1cm then it pulls off :)
poLoTDI1.4
haha oh right.... when you said half a turn i thought you meant half a turn of it all :oops:
tomorrow morning i shall have a look!!
Thanks!
poLoTDI1.4
well i finally got the problem sorted!!
the black/white wire was split in two in the rubber thing. reconnected and im all up and running.
brown was frayed a little, i suspect this is the earth?
and i can't get the rubber boot back on! but it was raining and freezing so ill try again soon!
Thanks for everyone's help.
Lisa
alexperkins
Site Admin
Ah superb :) Rubber boot is a bugger to get on. Try warming it a little
poLoTDI1.4
ok ill give it a blast, prob be next weekend again though as i've nowhere inside to work! I'll warm it when i'm taking the badges off!
