Gave the car a scan with VAGCOM
2 codes showing up:
16520 P0136 O2 Sensor Circuit - Malfunction (Bank 1 Sensor 2 A
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 35-10 - - - Intermittent
A lot of people hated the laggy, smelly, gas guzzling turbo cars of the 80s (I didn't!) but do you know what? I miss them! Turbo engines these days try to be so smooth, you wonder if the engine is actually turboed at all! BMW 335i for example! Try one if you haven't already....see if you can detect a boost hit!more-bhp wrote:Marcopolo.... you are spot on... the electronic boost control... ie N75.. is Cr*p... and the ECU's unfortunately pick up on it... and try too hard to control everything...
I've never liked these little N75 type things.... bring back the old school and the Bleed Valve !!
Thats why we try to make software smoooooooth ...
I second that notion!more-bhp wrote:So thats why I want a BIG turbo delivering low boost...its the way to go IMO... and thats what I'm looking at sorting....
