Tim's GTI. update thread, FOR SALE. NEW WINTERS PG 51
kaz
Re: Tim's GTI. update thread, GETTING THINGS BACK ON TRACK!
Post by kaz »
liking the colour coding my friend, gonna need to see some pictures of the bay when all done! Guessing u were back down from uni for the weekend then?
changed my oil today too, its all aobut mobil 1 esp ;) bit pricey tho :|
Tim_GTi
Post Whore
Post by Tim_GTi »
Gunna strip it back down, give it a good solid polish down, then build the paint back up i think.
Yeh was back for the weekend, was pretty hectic! sucked having to drive my brothers skoda round whilst working on the car though :(
kaz
Post by kaz »
thats cool will look really good when finished!
not much going on in the world of my lil polo, everything is due next month, insurance etc the works.. so somehow need to finance that :( so just been playing around n trialling some new cleaning jobbies..like the car lack brand and opti-seal - just trying to find the best combo of stuff to make silver look at its shinest ;)
Tim_GTi
Post Whore
Post by Tim_GTi »
Heard good things about carlack, makes a good combo with collinite 476s wax!
Trottagti
Post by Trottagti »
Your flaking issues will be because of poor adhesion, Did u guys key up the area and make it like non shiny as in scrathed it and did u use the correct halfords cleaner and plastic primer with plastic cleaner on the plastic bits obviously lol :wink: , allowing time between coats aswell???
Halfords paint is poor by any means!
Tim_GTi
Post Whore
Post by Tim_GTi »
Trottagti wrote:Your flaking issues will be because of poor adhesion, Did u guys key up the area and make it like non shiny as in scrathed it and did u use the correct halfords cleaner and plastic primer with plastic cleaner on the plastic bits obviously lol :wink: , allowing time between coats aswell???
It's not the plastic parts I'm having issues with as they're great, it was the heat shield. I cleaned the surface, then ran 600 grit over it to key it, but it still flaked. I think I probably should've stripped it down a bit further, maybe it wasn't clean enough before hand?
How would you advise I go about spraying it?
Trottagti
Post by Trottagti »
Well u have keyed it up enough for sure, did you use solvent based cleaner, ie panel wipe or summin to clean it with and did u wait in between ur coats as if u didnt that will have a big effect as ur putting like one massive coat on, i take it its a matt finish red heat resistance paint? i would wait 10 mins inbetween coats applying very thin coats, as its matt u dont need to worry a huge amount, take all the paint off and give it a good go over with cleaner and apply thin coats, i would slighty heat inbetween coats not alot at all just warm in the room and heat the sheild before painting aswell buddie!
Tim_GTi
Post Whore
Post by Tim_GTi »
Yeh i didn't use any solvent based cleaner in the end, I applied roughly four thinnish coats, with use of a hairdryer inbetween the last couple of layers. Also been soaking the cans in warm water before hand to warm the paint.
I'll strip it back down and give it another go, with some proper cleaner, and even thinner and more coats, cheers.
Trottagti
Post by Trottagti »
Its not you its the poor quality paint and conditions is all! But yeah ur on the write track!
Tim_GTi
Post Whore
Post by Tim_GTi »
Right.
Excluding my rocker cover and re-doing the heat shield, my engine bay parts are finished being sprayed!! They'll go on tomorrow night when I'm home.
This weekend will also see me starting the first stages of The Detail on the Polo!!
It'll be washed dried and clayed on Friday, then the machine polish will finally commence Saturday 8)
Watch This Space.
h4r1s
Location: Leicester/Sheffield Drives: Polo MKV-6N2 1.4SE 16v 75BHP
Post by h4r1s »
Wooop can't wait to see the next set of updates 8)
You coming down to ultimate dubs Tim?
Tim_GTi
Post Whore
Post by Tim_GTi »
Ahhh shoot, I totally forgot about it haha. No, i was going to try and get a lift down, but have organised to go home now!
Tim_GTi
Post Whore
Post by Tim_GTi »
Very successful weekend in regards to work on the car! Will get pics up when i'm back tonight 8)
Tim_GTi
Post Whore
Post by Tim_GTi »
Finally got everything put back into the engine bay! really pleased with the results.
I painted the following:
Washerfluid bottle
Coolant bottle
Coolant cap
Brake fluid cap
Power steering cap
Washer fluid cap
Also striped the underbonnet of it's sound deadening and cleaned. Stripped the battery of all stickers. And generally spruced it all up.
Before shot:
After shots:
Things still to do:
Re-paint the rocker cover (you can notice the flaking on some of the pics)
Paint the Dip stick handle (probably black, maybe red though)
Clean deeper in the bay (only touched the surface)
Get some new strut bolt caps
I also annoyling jabbed the washer fluid bottle with a screwdriver and a bit flaked off, so that needs re-doing.
Let me know what you all think.
Detailing updates to follow. Just need to sort out all the pictures
adam_0612
Re: Tim's GTI. update thread, ENGINE BAY DONE PG24
Post by adam_0612 »
was not expecting it to look like that at all tim, that looks truly fantastic!!!
very tidy engine bay now, massive difference from before!
for your dipstick handle, i would definetley paint it red.
