Service Time... Which oil?
- TimGti
- Drives: 9n3 1.9 Tdi Sport
Need to service my girlfriends 2001 1.4 8v Match soon
Book says 501 01? Are we talking 10w-40 like the Castrol Magnatec or 5w-30 like the Castrol Edge? A little confused as to what I need as the 501.01 thing is never mentioned anywhere!
I seem to remember the VW dealers was cheaper than Halfrauds last time I had to do this, is this the case?
- Tim_GTi
- Post Whore
Re: Service Time... Which oil?
Go with 10w/40. I was going to get Magnatec for mine but was advised against it by GSF. i went TItan XTR in the end, runs great. And was under £20 for 5l from GSF.
5L tim isnt it lol
I think GSF recommended the fully synthetic 0w/40 for you didnt they tim?
I changed the oil in mine earlier. Castrol Magnatec 10W/40 as I fancied using a premium oil to allow for longer time between changes. Its running sweet as a nut, and cost me less than retail due to trade woo!
- Tim_GTi
- Post Whore
Yeh sorry i ment to type 5l, not 4. I've corrected it
yeh GSF recommend fully syn oil for the GTi.
It can be run on 0w40. I researched it earlier lol but once you change to fully synth you have to stay there, and its expensive!
- Tim_GTi
- Post Whore
Yeh that's what I've always thought, it's really not that expensive actually. The stuff they recommended (can't remember what it was now) was £19 for 5l.alexperkins wrote:It can be run on 0w40. I researched it earlier lol but once you change to fully synth you have to stay there, and its expensive!
- TimGti
Mobil Super S 10w 40 £19 ish from Halfrauds might just get that, or maybe £25 for the 10w 40 Castrol Magnatec. Not feeling the £40+ for the fully synthetic Castrol Edge stuff, unless its actually needed!
Might just pop in to VW & ask them for prices as GSF is miles away from me!
VW is well overpriced for oil lol. GSF sell Fuchs Titan XTR 10w40 for 15 quid a bottle and its great stuff. You only need the top quality (inc fully synthetic) on something like a GTI.
- Tim_GTi
- Post Whore
GSF deliver, fast also. So travel isn't an issue. You can get your oil filter from them also.
- TimGti
Cheers lads. Will sort this one out when I get 5 mins. Need a new leccy window switch on drivers side to. Tried repairing thecurrent one but the contacts are mega corroded
- TimGti
Right. Had a look in today at the filter. How the hell do you get the tool on/ turn it to release the filter when its in such a s**t place, surrounded by other things? Normally I put the filter removal tool on the base of the filter and turn, but poxy VW have put it in a place that you cant do this!
Is it ok to put a socket on the end of it (on that big nut) and apply pressure to undo it? I tried this but it was done up pretty tight and was scared of breaking it!
Is it ok to put a socket on the end of it (on that big nut) and apply pressure to undo it? I tried this but it was done up pretty tight and was scared of breaking it!TimGti
It's quite safe to use a socket on that nut, in fact that's what it is intended for. I only buy filters with that nut on - makes life so much easier! The torque setting is 14lbs by the way.
- Tim_GTi
- Post Whore
Sucks when they round off though, then your in a right pickle as I've descovered before
- TimGti
I tried undoing it with a socket and was propper tight. I then put a long bar on the socket for more leverage but was a little scared to put too much pressure on it for the reasons above! Im sure these are supposed to be done up hand tight! Whoever put mine on was using a little more than that to tighten it
I cant risk kanckering it as I the girlfriend needs the car everyday so I don't want to force it and wreck it. Why cant they just put it in a place thats easy to get to like on all other cars Ive had
It turns to left - i hope your turning it that way
If it really wont budge, you may need a proper filter wrench on it for removal
