Service Time... Which oil?
TimGti
Drives: 9n3 1.9 Tdi Sport
Post by TimGti »
Need to service my girlfriends 2001 1.4 8v Match soon
Book says 501 01? Are we talking 10w-40 like the Castrol Magnatec or 5w-30 like the Castrol Edge? A little confused as to what I need as the 501.01 thing is never mentioned anywhere!
I seem to remember the VW dealers was cheaper than Halfrauds last time I had to do this, is this the case?
Tim_GTi
Post Whore
Re: Service Time... Which oil?
Post by Tim_GTi »
Go with 10w/40. I was going to get Magnatec for mine but was advised against it by GSF. i went TItan XTR in the end, runs great. And was under £20 for 5l from GSF.
alexperkins
Site Admin
Post by alexperkins »
5L tim isnt it lol :P
I think GSF recommended the fully synthetic 0w/40 for you didnt they tim?
I changed the oil in mine earlier. Castrol Magnatec 10W/40 as I fancied using a premium oil to allow for longer time between changes. Its running sweet as a nut, and cost me less than retail due to trade woo!
Tim_GTi
Post Whore
Post by Tim_GTi »
Yeh sorry i ment to type 5l, not 4. I've corrected it 8)
yeh GSF recommend fully syn oil for the GTi.
alexperkins
Site Admin
It can be run on 0w40. I researched it earlier lol but once you change to fully synth you have to stay there, and its expensive!
Tim_GTi
Post Whore
Post by Tim_GTi »
alexperkins wrote:It can be run on 0w40. I researched it earlier lol but once you change to fully synth you have to stay there, and its expensive!
Yeh that's what I've always thought, it's really not that expensive actually. The stuff they recommended (can't remember what it was now) was £19 for 5l.
TimGti
Post by TimGti »
Mobil Super S 10w 40 £19 ish from Halfrauds might just get that, or maybe £25 for the 10w 40 Castrol Magnatec. Not feeling the £40+ for the fully synthetic Castrol Edge stuff, unless its actually needed!
Might just pop in to VW & ask them for prices as GSF is miles away from me!
alexperkins
Site Admin
VW is well overpriced for oil lol. GSF sell Fuchs Titan XTR 10w40 for 15 quid a bottle and its great stuff. You only need the top quality (inc fully synthetic) on something like a GTI.
Tim_GTi
Post Whore
Post by Tim_GTi »
GSF deliver, fast also. So travel isn't an issue. You can get your oil filter from them also.
TimGti
Post by TimGti »
Cheers lads. Will sort this one out when I get 5 mins. Need a new leccy window switch on drivers side to. Tried repairing thecurrent one but the contacts are mega corroded :(
TimGti
Post by TimGti »
Right. Had a look in today at the filter. How the hell do you get the tool on/ turn it to release the filter when its in such a s**t place, surrounded by other things? Normally I put the filter removal tool on the base of the filter and turn, but poxy VW have put it in a place that you cant do this!
Is it ok to put a socket on the end of it (on that big nut) and apply pressure to undo it? I tried this but it was done up pretty tight and was scared of breaking it!
jonnopolo
Post by jonnopolo »
Is it ok to put a socket on the end of it (on that big nut) and apply pressure to undo it? I tried this but it was done up pretty tight and was scared of breaking it!TimGti
It's quite safe to use a socket on that nut, in fact that's what it is intended for. I only buy filters with that nut on - makes life so much easier! The torque setting is 14lbs by the way.
Tim_GTi
Post Whore
Post by Tim_GTi »
Sucks when they round off though, then your in a right pickle as I've descovered before :roll:
TimGti
Post by TimGti »
I tried undoing it with a socket and was propper tight. I then put a long bar on the socket for more leverage but was a little scared to put too much pressure on it for the reasons above! Im sure these are supposed to be done up hand tight! Whoever put mine on was using a little more than that to tighten it :evil:
I cant risk kanckering it as I the girlfriend needs the car everyday so I don't want to force it and wreck it. Why cant they just put it in a place thats easy to get to like on all other cars Ive had :evil:
alexperkins
Site Admin
It turns to left - i hope your turning it that way :P
If it really wont budge, you may need a proper filter wrench on it for removal
