headlght bulb replacment
birdie34
Post by birdie34 »
Hi Ive just went out and brought a polo gti and noticed the bulb has gone i tryed to change the bulb but cant get plastic cover off any ideas?
alexperkins
Site Admin
Re: headlght bulb replacment
Post by alexperkins »
pull the rubber surround off, then the light fitting twists and pulls off, then you can release the bulb and remove, replace and refit.
its unlikely the bulb has died though, so get the ballast tested, and check the fuse as these normally last forever!
birdie34
Post by birdie34 »
i will try thanks
birdie34
side light front bulb replacment
Post by birdie34 »
the head light is ok the side light is gone and is in a plasic moulding any ideas how to remove this moulding?
alexperkins
Site Admin
Just pull it firmly
Tim_GTi
Post Whore
Post by Tim_GTi »
Hang on, are you referring to the rear palstic cover of the headlight? If so it's held in by 3 small crosshead bolts. Look here:
http://www.uk-polos.net/view ... ts#p257389
birdie34
Post by birdie34 »
thanks
