Wheel Bolts
Wheel Bolts
Hi, i was wondering if any1 could help with the following; ive got a 9n polo, i am changing from steel wheels to audi tt comps, ive been told i need longer bolts, is this true as i am not too clued up on this topic? if so where can i purchase some from and how much is it going to cost me roughly thanks, any help will be appriciated.
Re: Wheel Bolts
iirc they are 40mm bolts, they aint that much from the dealer
Re: Wheel Bolts
I thought the stock wheel bolt's were 30mm, but could be wrong
Just had to buy longer wheel bolts myself for the front, as I have added a bigger brake kit - M14 1.5 60mm were R63.78 a bolt, which is probably a few pounds, but bloody expensive compared to the same M12 size...
Nic
Nic
Re: Wheel Bolts
im currently running on tt comps with my original bolts and theyre fine.
