I have a terrible noise from my driver side front wheel, just had both front wishbone replaced and noticed there is "play" between the 2 rims on the driver side front wheel...I am happy enough to torque up the rim bolts to see if that cures it but has anybody else had this? I'm pretty sure they will get loose again even if I can tighten them up and if it's going to be an on-going issue, not sure if it's better to just bite the bullet and buy new wheels
I am running on 16" 4x100 BBS split rims (from GTi Cab) with adjustable springs.
loose split rims
Redline
- Sponsor
- Drives: BMW 128ti
Re: loose split rims
Do you know if they have been refurbished at some point? I've personally never heard of the centre coming away from the rim like that.
They should be torqued up to 30NM (22 lb ft). I'd also suggest using Loctite on the bolts as well.
thanks very much for the response...will give that a go and see how I get on....i don't know for sure but i would probably wager they have been refurbed at some point...given their condition and age....
it's definately the wheel making the noise, i have stuck my spare on and not a sound
alloy had a split in it...so if anybody has a spare they want to sell please let me know
cheers
cheers
Redline
- Sponsor
- Drives: BMW 128ti
Ah!
Is it the centre or the rim that has a split in it?
If its the center you need...i have a spare center lol
it's the centre...so yes would take if you have
Ill have to check it will fit the 16" ones (conveniently i can measure my polo as I run the 16s on my car
) will let you know soon
magic, cheers fella
did you get a chance to look as yet Alex? cheers mate
