Hialexperkins wrote:you need to plug it in and loads the instruments group (not engine 01) and check for fault codes as these have their own diagnostics.
Just done and this is all that comes up??
i guess i can try removing the wiring from the sensor connector and refit in case there is a bad contact, other than that Im stumped
irishkeet
