OEM Horn circuit
OEM Horn circuit
I have just bought a dual horn to replace the existing OEM one. The new one comes with a relay, but was wondering if I needed it. The diagram suggest a circuit with a 10A fuse in it. Does anyone know what the current circuit can draw and if the new relay is required to be used?
Re: OEM Horn circuit
the existing wiring should hold out. If not, just put the relay in direct to the battery and ground it on the existing ground.
Think I will put the relay in, just to make sure. So will use 85/86 to connect to the existing horn wiring and use 30/87 to link the new horn to the battery.
Not looked at the battery yet - are there specific connections you can hook a new wire onto?
