foglights
jonny6n2
foglights
Post by jonny6n2 »
i have a 6n2 with no foglights how easy is it to convert them? is the wiring already there or does it need to be done in the manufacturing process?
kingsleysaywell
Re: foglights
Post by kingsleysaywell »
i think its there
jonny6n2
Re: foglights
Post by jonny6n2 »
can anyone just confirm this?
sylvester
Re: foglights
Post by sylvester »
Remove the blank foglight covers and you should see the plugs if fitted, they're connected to clips on the inner wings, all you need if the connectors are there is a new light switch with the front fog position, simples!
jonny6n2
Re: foglights
Post by jonny6n2 »
thanks for the replays guys
kingsleysaywell
Re: foglights
is the switch for the rear fog not the same as the front ones?
Tim_GTi
Post Whore
Re: foglights
Post by Tim_GTi »
kingsleysaywell wrote:is the switch for the rear fog not the same as the front ones?
no it's separate, so if your switch doesn't have both on it you need to buy another switch which does support both.
kingsleysaywell
Re: foglights
have you got a picture of the new switch i would need ?
Tim_GTi
Post Whore
Re: foglights
Post by Tim_GTi »
They look exactly the same, but pull out once for front fogs, then further again for the rear fog.
kingsleysaywell
Re: foglights
oh right thanks
Tim_GTi
Post Whore
Re: foglights
Post by Tim_GTi »
kingsleysaywell wrote:oh right thanks
Actually after looking at it, there's another light to signify the front lights that comes on when they're selected, this is the only visual difference. It's located right next to the rear fog light symbol on the dial.
kingsleysaywell
Re: foglights
so does that mean the switch is the same?
Tim_GTi
Post Whore
Re: foglights
Post by Tim_GTi »
No the switches are definitely different, but there is small visual difference to them. The only visual difference being that there is a small front fog icon next to the rear fog icon on the switch.
kingsleysaywell
Re: foglights
but i could use the same switch it just wont have the icon? is that right? :S
Tim_GTi
Post Whore
Re: foglights
Post by Tim_GTi »
kingsleysaywell wrote:but i could use the same switch it just wont have the icon? is that right? :S
No because the switch has different modes for each fog. Pull out once for front fogs, twice for rear fog.
Standard switch only has pull out once for rear fog.
