foglights
kingsleysaywell
Re: foglights
i think its there
Re: foglights
can anyone just confirm this?
Re: foglights
Remove the blank foglight covers and you should see the plugs if fitted, they're connected to clips on the inner wings, all you need if the connectors are there is a new light switch with the front fog position, simples!
Re: foglights
thanks for the replays guys
kingsleysaywell
Re: foglights
is the switch for the rear fog not the same as the front ones?
- Tim_GTi
- Post Whore
Re: foglights
no it's separate, so if your switch doesn't have both on it you need to buy another switch which does support both.kingsleysaywell wrote:is the switch for the rear fog not the same as the front ones?
kingsleysaywell
Re: foglights
have you got a picture of the new switch i would need ?
- Tim_GTi
- Post Whore
Re: foglights
They look exactly the same, but pull out once for front fogs, then further again for the rear fog.
kingsleysaywell
Re: foglights
oh right thanks
- Tim_GTi
- Post Whore
Re: foglights
Actually after looking at it, there's another light to signify the front lights that comes on when they're selected, this is the only visual difference. It's located right next to the rear fog light symbol on the dial.kingsleysaywell wrote:oh right thanks
kingsleysaywell
Re: foglights
so does that mean the switch is the same?
- Tim_GTi
- Post Whore
Re: foglights
No the switches are definitely different, but there is small visual difference to them. The only visual difference being that there is a small front fog icon next to the rear fog icon on the switch.
kingsleysaywell
Re: foglights
but i could use the same switch it just wont have the icon? is that right? :S
- Tim_GTi
- Post Whore
Re: foglights
No because the switch has different modes for each fog. Pull out once for front fogs, twice for rear fog.kingsleysaywell wrote:but i could use the same switch it just wont have the icon? is that right? :S
Standard switch only has pull out once for rear fog.
