coilovers and droplinks
matt_123
Post by matt_123 »
Finally im ordering some coilies to lower her !!
Ive decided on AP coilies they seem like a gd deal.
When they get fitted i don't want any rattles or knocking noises the drop links i need are they mondeo ones?? do i need to replace anything else?? its a 1.6 btw not a gti :wink:
Thanks Matt
matt_123
Re: coilovers and droplinks
Post by matt_123 »
http://cgi.ebay.co.uk/FORD-MONDEO-1993- ... 3a546ef436
are these the right ones?? and would they stop the knocking noise? :roll:
POLOZ
Post by POLOZ »
Dont mind me asking! How much did the coilly's cost you?
zedzo
Post by zedzo »
yes u need mondeo drop links make sure u get the correct ones, its better to go to a store (ford or carcraft etc) as you can see that its the correct one as i bought sum of ebay i think they must of bin the newer model as they was exactly the same size as my current ones. the correct ones shut b a little bit smaller n fatter.
matt_123
Post by matt_123 »
I haven't got them yet but there £365 from venom motorsports9last time I checked) guna order them this week hopefully along with the mondeo droplinks if someone could maybe tell me which ones to get from the earlier mondeos. or any other droplinks that would fit????
david burton
Post by david burton »
Is that a known issue with the AP ones? When I changed to KW coilovers the mounting point for the droplink was different so I didn't have an issue when I used the original ones..... might be worth checking if you definitely need to with AP ones.
matt_123
Post by matt_123 »
oh really? well i mite have to check.
Can anyone shed an light on this people who have AP coilies ?? :D Kenny I know you have got some
Gillen
Post by Gillen »
david burton wrote:Is that a known issue with the AP ones? When I changed to KW coilovers the mounting point for the droplink was different so I didn't have an issue when I used the original ones..... might be worth checking if you definitely need to with AP ones.
Same with my Weitec's, the mounting point for the droplink was much higher up the damper than the original one.
david burton
It's probably worth waiting until you get the APs and then comparing. A couple of days with long droplinks won't kill the car if you don't lower too much.
matt_123
Post by matt_123 »
okay mate ill wait till i get them. I just wanted everything to go on while its gettin done anyway so everything will be perfect .
Cam 9n3
Post by Cam 9n3 »
Don't waste your money with mondeo links, buy vmaxx shortened links. They are considerably shorter than the mondeo ones and cheaper! Winner! :D
Tim_GTi
Post Whore
Post by Tim_GTi »
Cam 9n3 wrote:Don't waste your money with mondeo links, buy vmaxx shortened links. They are considerably shorter than the mondeo ones and cheaper! Winner! :D
True, the mondeo droplinks are only ever so slightly smaller than the polo ones, where as the Vmaxx ones are tiny.
If your going really low go with Vmaxx to be safe, 50mm or above mondeo ones will do fine.
RoSonic
Post by RoSonic »
Where have you found the vmaxx ones cheaper than mondeo links ?
as from what i've found mondeo - ~10gbp and vmaxx ~45gbp
Tim_GTi
Post Whore
Post by Tim_GTi »
YEh vmax ones are definitely alot more expensive.
ryandel
Post by ryandel »
were can you get the vmaxx ones guys?
