Temperature Light flashes
polo_tdi
Post by polo_tdi »
Hi, I really need some help.
A few months back my 1.4 TDI polo overheated and the temperature light on the dash started to flash. after taking to the garage soon after, i was told the waterpump needed replacing, so i got that done.
temperature of the car now seems to be ok, but for some reason the temperature light on the dash starts to flash roughly 10mins after the car is started, having read this forum it all pointed to the temperature sender (i believe some people call it "sensor"). i replaced that without any problems, toped up the coolent + water.. and problem still persits :(
Its so annoying to have the light flashing while im driving when there doesnt seem to be any issues.
does anyone out there have any idea's on what could be causing this?
all thoughts appriciated
alexperkins
Site Admin
Re: Temperature Light flashes
Post by alexperkins »
id get it plugged into vag com - its better to have the proper codes to tell if there is something wrong internally in the coolant system :)
polo_tdi
Post by polo_tdi »
alexperkins wrote:id get it plugged into vag com - its better to have the proper codes to tell if there is something wrong internally in the coolant system :)
thanks alex, i know a mate who has this so i'll pick it up later this evening and give it ago. my mates out of town at the moment so i wouldn't be able to ask him on how to use it.
Any pointers?
alexperkins
Site Admin
ignition on, plug in the cable under the ashtray, load up vag com, choose Engine 01 then fault codes
are you using a PC with it already installed, or will you be installing it first?
The fault could well be a faulty coolant level sensor in the expansion tank - check its properly plugged in and clean the contacts.
polo_tdi
Post by polo_tdi »
Top stuff, it's already installed (i believe) on his laptop.. fingers crossed i can get it working.
alexperkins
Site Admin
any problems just let me know ;)
pvr
Post by pvr »
Sounds an excellent piece of kit, must have a look into that one ...
polo_tdi
Post by polo_tdi »
So.. i managed to pick up the kit..
pluged it all in, turned on the ignition and ran the test. Outcome = no error codes.
so then i proceeded to tuning my car on and waiting for the temp light to show up. i waited 10mins, then 15, then 20.. NOTHING! the light didnt turn on, and the temp gauge didnt go up either.
i know it was cold yeasterday (i live in east london). should i have let the engine run for longer?
alexperkins
Site Admin
20 mins you should see some movement. it sounds like you have a fault somewhere along the lines mate
polo_tdi
Post by polo_tdi »
Hi Alex,
managed to get a bit more intimate with the VAG-COM sw..
it spat out the following codes:
Address 01: Engine
Protocol: KW1281
Controller: 045 906 019 AB
Component: 1,4l R3 EDC 0000SG 1210
Coding: 00003
Shop #: WSC 00788
Address 03: ABS Brakes
Protocol: KW1281
Controller: 6X0 907 379 B
Component: ABS 30 IE CAN V004
Coding: 05603
Shop #: WSC 01234
I'm kind of ok withe the ABS error as thats been an intermittent problem for about the last 3-4 weeks. any idea what the first one is.. and would you know if it would be related to the temp light problem i've been having?
alexperkins
Site Admin
Thats not error codes you have printed there - thats just controller numbers. You need to go into the Engine 01 Group and then go to Fault Codes to retrieve the codes in a sensible format mate ;)
vw55raz
Post by vw55raz »
where abouts east london are u? i know someone who does vagcom error code checking.
