thanks for that sandy, but i am afraid that may not fit as i cannot figure out how it can be connected with the hand brake cable but thanks anyway.
jeff, what you have on the rear should be from mark 4 golf 20th edition (337/20) right? are they the same setup? i found something on ecstuning: http://www.ecstuning.com/Volkswagen-337 ... ar/ES1959/
is it the same caliper that you're using?
khfluk wrote:thanks for that sandy, but i am afraid that may not fit as i cannot figure out how it can be connected with the hand brake cable but thanks anyway.
cheers
yes you are correct in stating that the front calipers will not do the rear
I have a set of front 312mm calipers and carriers off an Octavia VRS...plus i have the rear 256mm calipers and carriers...these can be sold as a whole set or will sell just the fronts or just the rears.
Make me an offer if your interested or PM if you want pictures
