1.4 MPG Question - what do you get>?
irishkeet
Re: 1.4 MPG Question - what do you get>?
Post by irishkeet »
Hi
yesterday I changed the coolant temp sensor for a genuine VW one.
If I leave the car running on the drive the temp goes to the middle fine but when i drove to work this morning it never reached the middle (50mph on an A road)
should it be reaching temp and in turn using less fuel?
cheers
keet
alexperkins
Site Admin
Post by alexperkins »
How far is it to work? It should heat up pretty quickly. Sounds like either your waterpump isnt working properly, or you have a blocked rad or a malfunctioning thermostat
irishkeet
Post by irishkeet »
alexperkins wrote:How far is it to work? It should heat up pretty quickly. Sounds like either your waterpump isnt working properly, or you have a blocked rad or a malfunctioning thermostat
Hi Alex
30 mins tops
if im stood in traffic or driving slowly the gauge will hit the centre ok
on a faster run it gets just less than a 1/4 of the way up.
I had a new pump fitted with the timing belt, the sensor is a new genuine VW one
and i flushed the rad the first time I installed a sensor
lol seems to be one thing after another, will check for faults with VAG again
cheers
irishkeet
irishkeet
Post by irishkeet »
hi
up to 300 miles a tank at the moment
I guess a motorway tank would be more
happy with that for now
irishkeet
J25LY
Location: Birmingham : Drives: EP2 05 : Drove: MK5 1.4S
Post by J25LY »
Hey mate!
£45 for a full tank and do about 60 miles a day! (to uni and back) :shock:
so i normally get around 330 - 340 miles just before going into the red
Plus mines a 1.4 8v
Regards
LoNg
kingsleysaywell
Post by kingsleysaywell »
how much you paying for petrol as to fill up my 1.4 8v costs about £30
red6n2
Post by red6n2 »
hi,
bringing up an old thread here but i reset my mile-o-meter (as i call it) when i last filled up and i have been driving very conservatively all month no over revving noting no fun whatsoever just went to go check it and im on 248.0 miles exactly with about a quarter of a tank left considering its only a 1.4 8v thats not very good is it ?. no problems with the cars temprature it sits in the middle fine and never differs once temp is reached, its done 137355 miles :roll: lol but as far as im aware the car is sound but is there anything i can replace or do to get a better mpg ???
red6n2
Post by red6n2 »
anyone ??? :?
alexperkins
Site Admin
Id get it scanned with vagcom
You could have a dodgy temp sensor, dodgy lambda, or your throttle body may simply need a clean out
red6n2
Post by red6n2 »
cheers, what roughly should i be getting do you think ?, throttle body is getting done wednesday and if that doesnt do it il get the lambda sensor changed, :D
alexperkins
Site Admin
350-380 a tank id say driven sensibly
Have it scanned first mate
