Help Needed Fixing my Electric Windows!
lowfoon
Post by lowfoon »
My passenger window only goes up from the driver's side but does not go down.
Aware of the common problem I check the wires between the doors. I had looked like the previous owner attempted to repair it before...
The black/White cable wasn't soldered unlike the brown cable so I cut it and decided to solder again.
What I had noticed was:
When the black white cable was connected; Passenger Side only went up + Driver's side worked like normal
When it was disconnected; Strangely the passenger side went down when up was pressed! + the driver's did not work at all
I can't get my head around this one!! :x
lowfoon
Re: Help Needed Fixing my Electric Windows!
Post by lowfoon »
bump
alexperkins
Site Admin
Post by alexperkins »
Sounds like an earthing fault - im to presume you taped the soldered repairs up so they couldnt touch?
lowfoon
Post by lowfoon »
alexperkins wrote:Sounds like an earthing fault - im to presume you taped the soldered repairs up so they couldnt touch?
Yup I did. How would I repair the earthing fault?
