Low Fuel warning lamp!!
dub6n2
Re: Low Fuel warning lamp!!
Post by dub6n2 »
d_austin974 wrote:how did you sort out the fuel light thing in the end? It happens to mine if I drive well into the reserve, takes a day or 2 for the car to realise I've filled the tank. Its not a major problem because, as you say, the gauge reads correctly but I would still like to get it sorted, if its an easy fix.
mine became a sort of major problem because then the gauge also started to get stuck. It isn't what I'd say an easy fix because I had to do an instrument console adaptation using VAG-COM every time it got stuck and vag-com has to be registered (or cracked :wink: hehe)
d_austin974
Post by d_austin974 »
I keep hearing this vag com thing mentioned in loads of different threads. What exactly does it do? I dont know if I would use it. Is it worth getting?
dub6n2
Post by dub6n2 »
d_austin974 wrote:I keep hearing this vag com thing mentioned in loads of different threads. What exactly does it do? I dont know if I would use it. Is it worth getting?
sry late reply saw it just now :oops: ... yeah it is quite useful to have vag-com. you can easily detect most problems the car has and therefore saves you money at the repair garage.
here's a link top the product: http://cgi.ebay.co.uk/VAG-COM-USB-KKL-O ... 796wt_1220
d_austin974
Thanks dude!
