Low Fuel warning lamp!!
dub6n2
Post by dub6n2 »
why is it that my low fuel warning lamp is remaining on whilst the tank is full (and the meter shows) . Also this time when I filled the tank the meter got stuck and started going up little by little every time I started the car again!! the lamp isn't the first time that remained on but usually after a few new starts it turns off. any help pls! As soon as I manage to fix a problem I have with VAG-COM I will give a cluster adaptation maybe it fixes it
Re: Low Fuel warning lamp!!
it sounds like an earth problem on either the clocks, or the fuel sender located under the drivers side rear seat.
dub6n2
Post by dub6n2 »
to say the truth last time I lifted the back seat there was a wire that was coming from a hole in the floor board with a horse shoe like connector at the end of it. it was connected to no where and it seems that it has never been connected to anything because it was intact. anyone know what it is for? It is not coming from the fuel sender
Interesting. Can you get a pic of the connector?
dub6n2
Post by dub6n2 »
yeah I,ll take a photo of the wire tomorrow morning. Sorry not connector but terminal like this : http://www.mobilehomerepair.com/media/img/G31-955.jpg if I can remember well!
interesting. id be interested to see where that comes from lol
dub6n2
Post by dub6n2 »
OK I went to have a look at the wire. it is nothing other than an earthed wire (to the nut holding the seat belts) !! still does not know where the other end is supposed to be connected to :( !! If anyone could have a look at his polo and check what is the use for this wire I would be very great-full :)
red6n2
Post by red6n2 »
I would mate but unfortunatly big red (my car) is still in the garage being resprayed and resmoothed. Should get it back tomorrrow night. So if noone else has I will look then mate.
dub6n2
Post by dub6n2 »
ohh that would be grate mate :D thanks a lot ... and good luck with the fresh car :wink: hope all goes fine
dub6n2
Post by dub6n2 »
managed to sort the light out by using vag-com :D . lets see if it happens again
dub6n2
Post by dub6n2 »
these are the photos of the wire I was talking about
that looks like the earth wire for a sub...follow it the other way and see where it leads to
dub6n2
Post by dub6n2 »
that's the problem, that it leads to nowhere, one side is grounded (connected to the seat belt mountings) and the other end is loose! could be that it was used by some previous owner for a sub but I think I saw a photo of another polo having the same wire so I don't know if it is fitted from new
if it connects to nothing, remove it - there is no need for it to be there. It definitely looks like an old sub wire.
d_austin974
Post by d_austin974 »
how did you sort out the fuel light thing in the end? It happens to mine if I drive well into the reserve, takes a day or 2 for the car to realise I've filled the tank. Its not a major problem because, as you say, the gauge reads correctly but I would still like to get it sorted, if its an easy fix.
