Wheel Spacers
Wheel Spacers
Is there anything bad about these spacers before I buy?
http://cgi.ebay.co.uk/20MM-Hubcentric-W ... 2104wt_941
Re: Wheel Spacers
hubcentric so should be good!
Re: Wheel Spacers
looks good enough mate
Re: Wheel Spacers
not really related to your question but i was wondering what spacers actually do? do they give you a wider profile?
Re: Wheel Spacers
hehe ... as they are placed between the wheels and hub the wheels would sit further out and therefore increase the overall width of the car from wheel to wheelI-Roo wrote:not really related to your question but i was wondering what spacers actually do? do they give you a wider profile?
Re: Wheel Spacers
I always thought that having your tire or rim poke out under the arch was illegal?
Ive always been told that the arch has to be the point furthest out from your car..?
Re: Wheel Spacers
dont quote me but i thought the tread of the tyre has to be under the arch, so u can get them to poke out and stretch the tyres as much as you want but the tread of the tyre cannot stick out past the arch5509433 wrote:I always thought that having your tire or rim poke out under the arch was illegal?
Re: Wheel Spacers
I am quite sure you are right because people use stretched tyres as an excuse to go over that problemRS_GT wrote:dont quote me but i thought the tread of the tyre has to be under the arch, so u can get them to poke out and stretch the tyres as much as you want but the tread of the tyre cannot stick out past the arch5509433 wrote:I always thought that having your tire or rim poke out under the arch was illegal?
Re: Wheel Spacers
i really need some spacers, but the wheels im plannin on getting are 8" wide, so il see if they need to be spaced after they are on. so hubcentric are the ones to get right?
Re: Wheel Spacers
If your wheels are 8J them you most probably need spacers...RS_GT wrote:i really need some spacers, but the wheels im plannin on getting are 8" wide, so il see if they need to be spaced after they are on. so hubcentric are the ones to get right?
Hubcentrics are just one type of spacers, and most probably the best ones - plus you shouldn't need longer wheel bolts
Re: Wheel Spacers
Hubcentrics are the spacers you need (best once because they center themselves on the hub not on the nuts, which eliminates vibration and wheel unbalancing) but you still need longer bolts if they aren't built in with the spacers ... at least that was the case for me. and don't forget to use spigots for better alignment and fitmentslowfoon wrote:If your wheels are 8J them you most probably need spacers...RS_GT wrote:i really need some spacers, but the wheels im plannin on getting are 8" wide, so il see if they need to be spaced after they are on. so hubcentric are the ones to get right?
and be careful how wide you go because I have 20mm on each side and it rubs with the arch even at standard height, let alone when I have people at the back!!
Re: Wheel Spacers
What's the spigot size required?
Re: Wheel Spacers
inside is i think is 57.1 outside depends on wheel/spacer, looking at the spacers in your listing dont think you need anylowfoon wrote:What's the spigot size required?
Re: Wheel Spacers
if your alloys already have them you need not worry. but make sure you buy the spacers with the right hub size of an exact tight fit.lowfoon wrote:What's the spigot size required?
Re: Wheel Spacers
i got these
they did the job heavy tho
