reset the ECU??
dub6n2
reset the ECU??
Post by dub6n2 »
as the title states how can you reset an ECU ppl?? could this be done via vag-com ( erasing the DTC or something like that?)
red6n2
Re: reset the ECU??
Post by red6n2 »
im curious as to why you would want to ?
dub6n2
Re: reset the ECU??
Post by dub6n2 »
cleaned and disconnected some sensors so I would like the ECU to learn the new readings (if it does actually learn them)
RS_GT
Re: reset the ECU??
Post by RS_GT »
im sure i remember reading somewhere you just have to disconnect the negative terminal on the battery
alexperkins
Site Admin
Re: reset the ECU??
Post by alexperkins »
If you have an error code, youll most likely need VAGCOM or as its now called, VCDS to clear the faults as the negative battery trick doesnt work well on these modern ECUs
dub6n2
Re: reset the ECU??
Post by dub6n2 »
I don't actually have error codes but as some of the sensors are now cleaner I would like the ecu to "learn" on the new readings if it is actually an adaptive ecu after all
dub6n2
Re: reset the ECU??
Post by dub6n2 »
btw talking about sensors the fuel meter is not working quite well all the time ... it should be the sender from the tank no??
RS_GT
Re: reset the ECU??
Post by RS_GT »
dub6n2 wrote:btw talking about sensors the fuel meter is not working quite well all the time ... it should be the sender from the tank no??
i think so theres like a float mechanism on the fuel pump inside the tank,(can be accessed from under the rear seats) i got a feeling the sensor is inside the pump, bit of a b**** to get to
dub6n2
Re: reset the ECU??
Post by dub6n2 »
yeah I tried to open it some days back!! the connectors and hoses were a little tough and I left everything untouched so not to break anything!!
alexperkins
Site Admin
Re: reset the ECU??
It'll automatically adapt without any reset needed if it needs to change.
dub6n2
Re: reset the ECU??
Post by dub6n2 »
alexperkins wrote:It'll automatically adapt without any reset needed if it needs to change.
ahh ok then thanks loads mate :)
