60/40 suspension kit on 16" on a 6n2??
- alanjwong
- Drives: 2001 VW Polo 6N2 1.4 16v 100BHP
Hello everyone,
Im trying to find out whether or not I can lower my 6n2 with 16" wheels on a 60/40 suspension kit.
The one Im thinking of getting is the H&R 60/40 cup suspension kit.
Any info would be greatly appreciated.
Re: 60/40 suspension kit on 16" on a 6n2??
yep you can dude, but it can go a lot lower than that
Josh_6n2_Polo
^ what he said ^
- alanjwong
The tyres im running are 195/40/16. Does that make any difference??
I dont want the wheels rubbing on the arches. Will I get any problems like that??
nope not really a problem, 40 is quite a low profile so you should be good, 60mm really isnt much on the 6n2 tbh, the 60/40 will give it a nice drop, but you will only start getting 'problems' after probably 80-90mm
- alanjwong
Thanks, Im now ordering the H&R 60/40 kit.
Cheers everyone
Cheers everyone
Youd never get that low on 16s
They are too wide for one!
Is 60/40 a good drop for speed bumps and such?
40 in the back to allow for the weight of a sub..
Ye it is. So long as you dont have too much rear weight.
- alanjwong
Who has done it with a 60/40 kit on 16"'s??????
Im getting confused.
as far as im aware mate, its not many. Most people do 60/40 on a 15 inch, but as DPM said it should be fine so you may as well just go ahead and get it ordered
- alanjwong
Alex, I still need it fitted by you though, you still up for it.
of course dude. Im always up for working on a car!
Whats the best to go by then?alexperkins wrote:Ye it is. So long as you dont have too much rear weight.
I currently have 2 12" subs in the boot
Eventually going to reduce to 1 when i have the money.
I want my car to still be practical, so still be able to have atleast 4 people in the car.
What drop do you recommend?
Oh, and probably..eventually be on 15's. SOmething like TH monos.. (is what im interested in currently)
f6had
The rear shocks on my wife's 6N2 are shot so I've got hold of a 60/40 kit (Jackson tuning setup)
Picking it up this week and will attempt to fit myself too.. Any advice before I go ahead? Haynes manual says I should replace the nuts with new ones? Is that true?
Also I'm looking at sourcing some BBS RX (I) 16' with ET35 offset. I assumed that would be perfectly fine (running on 195/40's) but reading the above comments.. can I expect some issues then???
