6n2 headlining
benmkiv
6n2 headlining
Post by benmkiv »
does anyone know how to remove this?
alexperkins
Site Admin
Re: 6n2 headlining
Post by alexperkins »
Remove all grab handles. Remove A, B and C pillar trims. Remove boot trim. Remove interior light and unscrew screws under there. Then carefully drop it down and out.
dub6n2
Re: 6n2 headlining
Post by dub6n2 »
ahh this will come in handy cos soon I ll have to take it out cos the headlinig is pealing off at the edges cos of the severe summer heat here!! Any suggestions of a good glue I can use that withstands the summer heat?
benmkiv
Re: 6n2 headlining
Post by benmkiv »
yeah im having exactly the same trouble as well peeling at the edges,
the main reason im doing it though is to replace the rubber aerial base seal but i figured two birds wth one stone.
also any help with glue would be great and do the pillars just pop off or secured anywhere?
d_austin974
Re: 6n2 headlining
Post by d_austin974 »
does anyone know of a detailed walkthrough on how to do this? I want to switch my antenna with a shark fin one.
