6n2 headlining
6n2 headlining
does anyone know how to remove this?
Re: 6n2 headlining
Remove all grab handles. Remove A, B and C pillar trims. Remove boot trim. Remove interior light and unscrew screws under there. Then carefully drop it down and out.
Re: 6n2 headlining
ahh this will come in handy cos soon I ll have to take it out cos the headlinig is pealing off at the edges cos of the severe summer heat here!! Any suggestions of a good glue I can use that withstands the summer heat?
Re: 6n2 headlining
yeah im having exactly the same trouble as well peeling at the edges,
the main reason im doing it though is to replace the rubber aerial base seal but i figured two birds wth one stone.
also any help with glue would be great and do the pillars just pop off or secured anywhere?
d_austin974
Re: 6n2 headlining
does anyone know of a detailed walkthrough on how to do this? I want to switch my antenna with a shark fin one.
