[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Horn not working?? *RESOLVED* - UK-POLOS.NET - THE VW Polo Forum
The horn on my polo gti has suddenly stopped working. I checked two fuses under the dash they seem ok. Any ideas what else it could be? Or where under the bonnet the wiring etc is? Maybe it's been disconnected somehow?
Ahhh that doesn't sound good! Any ideas how to check that? Expensive? When the horn was working before. It only worked with the key in the car - not when the key out the car
Naa, still not working sadly, think iv managed to find where the horn is, but can't see it, need to put the car on a ramp I think.
Iv checked two fuses under the dash - 19 an 22 I think it was an they seem ok. Not done anything else unfortunately due to bad weather an bein an work - need to get it sorted asap tho!
I only got the contacts behind the steering wheel to check but im not taking that apart. Going to see if any electricity is getting to the actual horn first.
