Roof/3rd Brake light bulb?
Hi guys
anyone know what bulb the 3rd brake light takes?
- blazeguarder
Re: Roof/3rd Brake light bulb?
It's an LED strip, you need to replace the entire thing
Doh, ok cheers mate
One guy on here replaced it with a strip of LED's from Maplin.
Do the proper replacement to check the good condition for its brake. It’s necessary that you know the right bulb. Probably, replacing it with a strip of LED's from Maplin is not a bad idea.
maglite
maglite
Polo*
is this for 6n2? cos i was wondering how you remove the cluster from the boot? i removed the rubber grommits but there are no screws or anything there....
mine has got condensation inside!
9N for me, might just try and get a new one
are the leds on these bulbs or proper leds? are they removable? went to the dealers and they said you can replace the bulbs in them...
- blazeguarder
It's just a strip of LEDs. They aren't removable so you need to replace the entire thing if it fails.
If they are quoting you stupid prices, there are loads on ebay usually. They are the same for the 9N and 9N3.
- blazeguarder
Whoops
never noticed that they were removable when I changed mine... really need to be more observant lol.
Sorry for the complete misdirection mate, glad you got it sorted out anyway.
No worries mate, I only found out when I emailed the dealers and the chap told me I could just replace the bulbs instead of the whole thing
They are not simply bulbs in the 2001 Polo. They are a soldered set of LED's, having said that it would be possible to re-solder in a new "bulb" if you had one.
The Maplin solution is among my other posts ... http://www.uk-polos.net/view ... 13&t=47029
Hope this helps
Ray
Hope this helps
Ray
Mine is a 2002 9N model so dont know if they had changed the design when the 9N came out
Hey, how did u gain access to the bulbs!? Can't seem to remove the red lens to get to them!
