I know the login ect required, I'm just lacking the VAG COM
Cruise control is enabled in the Engine module (01) and in the Steering Wheel module (16) by adding the correct stalk you should be OK to just enable it with no other changes.
If anyone can make sense of that?!1. VAG Com software Laptop Diagnostic Line 2 Steering column with GRA function 3 Line set of www.kufatec.de
First, the engine control unit for GRA is coded. This login via computer with the diagnostic code 11 463 and engine control unit.
