Merseyside VAG COM - Anyone willing for a quick tenner?
BennoGTi
Post by BennoGTi »
Anyone willing to enable cruise control on my 9N3 for a small fee? Say £10?
I know the login ect required, I'm just lacking the VAG COM
Cruise control is enabled in the Engine module (01) and in the Steering Wheel module (16) by adding the correct stalk you should be OK to just enable it with no other changes.
1. VAG Com software Laptop Diagnostic Line 2 Steering column with GRA function 3 Line set of www.kufatec.de
First, the engine control unit for GRA is coded. This login via computer with the diagnostic code 11 463 and engine control unit.
If anyone can make sense of that?!
chris meardon
Re: Merseyside VAG COM - Anyone willing for a quick tenner?
Post by chris meardon »
Sounds like youve got it working then mate?
All except the vag com....
BennoGTi
Post by BennoGTi »
Yep, well at least as far as I can tell without VAG COM
That guide you sent me is pretty spot on, only 2 difficult bits really
Connecting into the back of the fusebox (not so bad)
And getting a pin into the connector on the firewall, so fiddly and hard to get to, my arm is cut to ribbons from it being jammed so far up the dash lol
chris meardon
Have you got any pictures of the fusebox bit so i can match my wires to yours? im going to order the kit soon, im sure i will need some of your time to talk through it the day i do it if thats ok?
BennoGTi
Post by BennoGTi »
I'm going to awesome gti tomorrow to get it activated, if all is well I'll take some pics of the fusebox
An yeh no problem mate, I'm happy to answer anything you need help with :-)
