Comming/ leaving home?
Joz
Post by Joz »
jem-9n3
Re: Comming/ leaving home?
Post by jem-9n3 »
hi mate, this was asked yesterday yoo.
here's the link to the forum, just read down abit
http://www.uk-polos.net/view ... 43&t=52660
Joz
Post by Joz »
What are you on about?!
That was a link to my video..?
Yes, I got a Chrome switch in my car, but no, it does not have the LEAVING/ COMMING HOME feature. That is what this post is about.
Will that work on our Polo's?
POLOZ
Post by POLOZ »
Good thing I waited before buying the one you suggested :D
I would be interested in this :D
Joz
Post by Joz »
Yeah! xD
Just saw it on a mates Golf, was awesome.
I'm sure you are aware that we have sort of the same function on our polos?
You know, when you tap the high beam..?
Only this would also provide the leaving home, which do not have as standard.
blazeguarder
Post by blazeguarder »
Doesn't look like it, the connector on the back of the switch in that photo looks different to me. I don't really see how the switch unit would be able to control the coming/leaving home lights anyway?
whitegtipolo
Post by whitegtipolo »
I have coming home u flash the headlights before u get out
POLOZ
Post by POLOZ »
blazeguarder wrote:Doesn't look like it, the connector on the back of the switch in that photo looks different to me. I don't really see how the switch unit would be able to control the coming/leaving home lights anyway?
Thats true! The connectors are quite different, infact ours have more.
POLOZ
Post by POLOZ »
whitegtipolo wrote:I have coming home u flash the headlights before u get out
huh? I just went and tried mine, no luck :( May be because I have HIDs?
Joz
Post by Joz »
Yeah, as I said, I do too.
Not leaving home though..
@ Poloz Well, guess it wont fit then.. :(
Also, you need a VAG-COM code to make it work, as the webpage says.
( If you want your comming home lights to work, here is how;
1. Leave the light switch in 0 ( off ) with the key in, but engine off.
2. Pull the signal marker
3. Lights are now on for 30sec. Remove key and lock car.
kc
Drives: an imaginary one... for now
Post by kc »
does anyone know which section of vagcom?
POLOZ
Post by POLOZ »
Joz wrote: If you want your comming home lights to work, here is how;
Sorry do you mean the full beam? If yes, I tried but no luck. Prob it needs activated :(
Joz
Post by Joz »
Well, my turn signal/ indicator-thingy is the same as the one with High beam control. So yeah :P
Then I guess it's because you have Xenons :/
blazeguarder
Joz, do you have the Winter Pack (headlight washers and heated seats)? I thought this function was only available on those cars...
Joz
Post by Joz »
Yes, I do.
Heated seats, wing mirrors, washer nozzles and retractable headlight washers.
Actually, if it is possible to get a winter package on a car, it is standard in Norway xD 6 feet of snow year round :P
