Comming/ leaving home?
Re: Comming/ leaving home?
hi mate, this was asked yesterday yoo.
here's the link to the forum, just read down abit
http://www.uk-polos.net/view ... 43&t=52660
What are you on about?!
That was a link to my video..?
Yes, I got a Chrome switch in my car, but no, it does not have the LEAVING/ COMMING HOME feature. That is what this post is about.
Will that work on our Polo's?
Good thing I waited before buying the one you suggested
I would be interested in this
Yeah! xD
Just saw it on a mates Golf, was awesome.
I'm sure you are aware that we have sort of the same function on our polos?
You know, when you tap the high beam..?
Only this would also provide the leaving home, which do not have as standard.
- blazeguarder
Doesn't look like it, the connector on the back of the switch in that photo looks different to me. I don't really see how the switch unit would be able to control the coming/leaving home lights anyway?
- whitegtipolo
I have coming home u flash the headlights before u get out
Thats true! The connectors are quite different, infact ours have more.blazeguarder wrote:Doesn't look like it, the connector on the back of the switch in that photo looks different to me. I don't really see how the switch unit would be able to control the coming/leaving home lights anyway?
huh? I just went and tried mine, no luckwhitegtipolo wrote:I have coming home u flash the headlights before u get out
Yeah, as I said, I do too.whitegtipolo wrote:I have coming home u flash the headlights before u get out
Not leaving home though..
@ Poloz Well, guess it wont fit then..
Also, you need a VAG-COM code to make it work, as the webpage says.
( If you want your comming home lights to work, here is how;
1. Leave the light switch in 0 ( off ) with the key in, but engine off.
2. Pull the signal marker
3. Lights are now on for 30sec. Remove key and lock car.
kc
- Drives: an imaginary one... for now
does anyone know which section of vagcom?
2. Pull the signal markerJoz wrote: If you want your comming home lights to work, here is how;
Sorry do you mean the full beam? If yes, I tried but no luck. Prob it needs activated
Well, my turn signal/ indicator-thingy is the same as the one with High beam control. So yeah
Then I guess it's because you have Xenons :/
- blazeguarder
Joz, do you have the Winter Pack (headlight washers and heated seats)? I thought this function was only available on those cars...
Yes, I do.
Heated seats, wing mirrors, washer nozzles and retractable headlight washers.
Actually, if it is possible to get a winter package on a car, it is standard in Norway xD 6 feet of snow year round
