Removing the inner door panel?
rasA4
Post by rasA4 »
Hi guys trying to get to the bottom of this creaking noise coming from the drivers electric window.
I have taken the door card off, and taken about 8 bolts off the metal plate behind that it seems the win I still can't take off the panel
It's a 9n3 2008
ali123
Re: Removing the inner door panel?
Post by ali123 »
There is probably around 16 or so greeny coloured metal bolts behind the door panel, they are all the same size. Once they are all out give it a good shove downwards and pull it out. I think you need to put the window down too
