Hi guys trying to get to the bottom of this creaking noise coming from the drivers electric window.
I have taken the door card off, and taken about 8 bolts off the metal plate behind that it seems the win I still can't take off the panel
It's a 9n3 2008
Removing the inner door panel?
Re: Removing the inner door panel?
There is probably around 16 or so greeny coloured metal bolts behind the door panel, they are all the same size. Once they are all out give it a good shove downwards and pull it out. I think you need to put the window down too
