1.2 tsi
daydotz
1.2 tsi
Post by daydotz »
I've had a polo bluemotion for a few days an found a few things I wondered if the 1.2 tsi suffered the same issues do you have to press the clutch while turning the ignition on ?
Is the clutch really light I stalled the bluemotion reversing up an incline every time
To get reverse do I needed to push the gear stick down an to the top left
I was quite shocked how bad the bluemotions gear box was it was clunky and clumsy to use An find gears How is the gearbox
Does it have a gear change indicator
Is it quite happy to sit in 5th at 30
AJ_7
Re: 1.2 tsi
Post by AJ_7 »
daydotz wrote:I've had a polo bluemotion for a few days an found a few things I wondered if the 1.2 tsi suffered the same issues do you have to press the clutch while turning the ignition on ?
Nope you don't have to press the clutch down.
daydotz wrote:Is the clutch really light I stalled the bluemotion reversing up an incline every time
The clutch is fairly light compared to other cars i've driven but I wouldn't say it's overly light.
daydotz wrote:To get reverse do I needed to push the gear stick down an to the top left
Reverse does require you to push the gear stick down and to the top left. I find the gearbox to be pretty smooth to be honest, but then again i'm used to it :)
daydotz wrote:Does it have a gear change indicator
Yep
daydotz wrote:Is it quite happy to sit in 5th at 30
Quite happily, you can go up most inclines in 5th at 30mph. If the road is flat or on a very slight incline my car is comfortable in 6th at 30mph, I never feel like like i'm labouring the engine.
Hope this helps :)
daydotz
Re: 1.2 tsi
Post by daydotz »
thanks the 1.2tdi bluemotion really had to work the gears to keep it happy considering the torque it had :shock:
