I am wondering what is the best route to uprating my brakes, i know alot of people do the tt option, but i dont quite have the funds for that, soooo i was just wondering what the best option? thanks for your help
Uprating Brakes On Polo GTI 1.8t
Hi guys!
Re: Uprating Brakes On Polo GTI 1.8t
I've got a set of front brake pads..
There green stuff pads brand new boxed..
If your interested send me a message with your offer..
I'm upgrading to tt brakes in jan so there no use to me
Green stuff pads are in no way an upgrade.
Best upgrade without changing calipers would be black diamond grooved discs with ferrodo ds2500 pads
buzzmotorsport
I found some 312mm brake from a mk4 gti which had brand new pads and good discs! For £160, not bad that so just shop around on ebay
Best brake conversion is as said either from a mk4 golf or a TT
definitely amazing off the TT!
buzzmotorsport
I always thought the tt and mk4 were exact same brakes! correct me if im wrong!
Don't know bout mk4 bt a know the mk5s have the 312 brakes
Think the r32s do? Or also the s3 brakes are 312 too!
Aye the old s3s the 20valvers
dood9n3
The old 8L S3, the 132kw mk4 and the TT all have 312 5x100 front discs
I just recently purchased a set of these
In pounds it was about 40 pounds for the set when they normally sell for close to 100 pounds per disk normally
buzzmotorsport
I need a set of those discs and pads to make the 312mm upgrade worthwhile I think! Standard pads don't bite well enough!
Mist importantly do they not fade right enough? Lol
what calipers does everyone put on the rear when theyve fitted tt front brakes? ive heard that the tt rear calipers dont fit off the quattro, ive seen online that some fit fabia vrs calipers!
dood9n3
s3 rear setup fits, just bolt on
