revo stage one remap
milltek catback
forge tip
stage one ecs clutch upgrade
should i have upgraded the spring inside the diverter valve?
thanks
Does anyone know if these are peak figures ?dood9n3 wrote:Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
Thanksbenmkiv wrote:These will be the peak at blow off.
You need yellow9N3 Turbo wrote:Does anyone know if these are peak figures ?dood9n3 wrote:Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
Mine peaks around 21 psi then settles down to around 10psi near the rev limiter
Yes i am but have a green springdrennan wrote:I will be the same en running the same software surly? Stage 2 revo 9n3 turbo yeah?
