Success: External temp in Climatronic screen
TriggerFish
- Location: Aylesbury, Bucks Drives: Polo GTi, 330d 'M-Sport'
Hi all,
Very quickly: does your climatronic unit display the outside temperature on the left of the screen?
The one in my Polo doesn't, but the one in the Golf does. Just wondering if it should do or not, as I can get a new Golf one for £5, and would quite like the temp on the A/C unit. (I might try swapping them over if I can be motivated/get the Golf one out easily!)
Cheers,
Joe
*Edit* Post 7 for solution!
Cheers,
Joe
- nigelelliott394
Quick Climatronic Question
Mine doesn't. I'd say it's probably because there's already the temperature reading on the clocks.
Doesn't really bother me that much though
TriggerFish
Re: Quick Climatronic Question
Cheers - it's on the Golf clocks too, with the MPG etc sitting between the two main dials.
Just for the sake of £5 it would be quite nice to have (if it's a unit specific thing) or useful as a spare anyway.
TriggerFish
Yeah, I've found the diagnostic mode before now - it's this I'm after:
I've read it's a coding option, so will have a quick look, see if it can be turned on with VAGCOM. I think all the cars use the same units, so buying another would be a waste of money.
TriggerFish
Hmm, might be doable:
http://wiki.ross-tech.com/wiki/index.ph ... nditioning
http://forums.vwvortex.com/showthread.p ... ot-working
If I'm right, the Polo should read: *40*1 at present. If I try changing that too *40*0 then maybe it'll display. I'll have to check the Golf too, see if that ends with a 0 or 1.
TriggerFish
- nigelelliott394
Very good
well done
- joe2612
- Location: Guildford, Surrey, Drives: Polo GTI 6n2 Black
Re: Success: External temp in Climatronic screen
Cheers for finding this out Joe, been wondering how to get that back
I've got this on mine but it's 1-2 out.... Does anyone know if it takes the temp from 2 different sensors???
TriggerFish
Mine differs a bit too. My conclusion is drawn from what it does on the Golf. The Polo gives whole numbers - 6,7,8 etc on the dash, the Golf *.5 too. 6.5,7,7.5 etc.
If it says 6.5 on the dash, it'll often say 7 on the climatronic. I'm guessing that it's just it rounding the numbers slightly differently to the dashpod. So the dash could go to 6, the climatronic 7. I think it's that anyway. Don't think there are two sensors, as on the Golf the sensor is iffy, and drops to -20c quite often, which also shows up on the climatronic. If there were two sensors I doubt that would happen.
I thought it mite be that but my climatronic would say 8 and the clocks would say 9 or 10 lol
Nice one dude,wonder what i'll be coding at the weekend.
TriggerFish
I see what you mean now - I had 6 and 12 showing on mine! Weird! I know the Golf had something where the temp reading didn't change until you'd driven a certain distance/time, maybe that's what the dash is doing, whereas the AC is in realtime? (I park in the shade in the mornings, so stands to reason.) Odd either way though!Ashcroft wrote:I thought it mite be that but my climatronic would say 8 and the clocks would say 9 or 10 lol
Ooo i didnt know we could do this! Off to check VCDS... lol
