hi guyssss
ok basically the other day my battery went dead, not sure why it was pretty new but i guess i was only doing very short journeys for a week and hadn't driven for a day or two.
regardless of that its happened before and I've jump started it and its been fine again.
however this time i started it and went to drive away 5 minutes later and the throttle didn't work. The engine management light is also on as is the EPC.
so when i press the throttle nothing happens and the car just idles.
i then restart the car and it works again.
any ideas?
preferably don't want to take it anywhere as I'm skint
thanks
jono
Throttle issue
Re: Throttle issue
what engine?
Re: Throttle issue
Probably the throttle position sensor.
I had this on my 1.4 16v, I sprayed a very small amount of carb cleaner into the throttle and it's worked fine for 9 month. Just be careful not to spray too much in and don't try and stick a cloth in and clean it as you'll knock the throttle position out.
Re: Throttle issue
its a 1.4 75bhp
Re: Throttle issue
ill give it a go, thanks,
just odd that it works after restart
