Could someone please confirm that this will fit my 2007 Polo GTi 9n3?
http://www.forgemotorsport.co.uk/conten ... t=FMVAG5QS
Many thanks
Thanks for letting me knowTurbomier wrote:it will fit don't worry...
Ibiza with BJX engine is exacly the same as the polo GTI.
so i'm 200% sure it will fit youre gearbox also![]()
you do know it is not a verry good solution for youre gearbox and it does have some drawbacks..?
not really my bussiness but i just wanne give you a heads up before buying something you might regret afterwards, or you get problems with it while we could have told you from the beginning
Hmm that's a shame... I quite fancied the idea of it. But the gti hasn't got long gear throws anyway so I'll live with it ha. ThanksTurbomier wrote:youre syncho's will suffer alot more than needed, specially when the engine is cold.
problem is, if you do want a decent short shifter you better get a complete tower but that is expensive.
but than again, loosing syncho's would not be that much cheaper...
Okay, we'll thanks alot as I would never have know all that if you hadn't told me.Turbomier wrote:you could be a lucky one without having problems...
i'm just telling it like it is and i've seen to many gearboxes go to waste with such "upgrades"
as long as it works, it's fine and all is well, but it's a mather of time for when it does go wrong...
Hmm okay, what bushings did you change? And what did you upgrade them too?noone025 wrote:A few of us from VWW forum have done this as well as upgrading the bushes. I like the change, not sure why shortening the shirt would damage the synchro if you shift normally. For me the big difference is that I don't lean forward a little to shift into 1,3&5. Installation can be done without removing the battery, but not easy.
