new to forum
Re: new to forum
ohh its standard though its not lowered atall? i think its been mapped to the k&n becuase when i put the airbox back on it doesnt run as nice. whaat? do you want to see those dunes????
lol
Re: new to forum
also with fitting 17 will its fill the arch more and look good with out lowering or will it just make the car taller? my dads into his transporters t4 and t5s buying making them look nice wheels lower and few engine mods and selling them on but he thinks bigger wheels will just fit nice in the arch but i think the gap between wheel and arch will stay the same.. can anyone confirm one of them?
- Ben90
- Drives: Olympian Blue Polo TDi Sport
Re: new to forum
17's won't make the car sit any taller. The overall diameter of wheel+tyre stays the same, so you fit larger rims and lower profile tyres. But there will be more alloy on show to 'fill' the arches
Best bet is to see how the Dunes look and lower from there. I don't think you'll be needing much unless you want to slam it! If 9n3 Turbo puts up a photo you'll be able to see what he's done
Re: new to forum
Yeah i grabbed those. No pics as yet been real lazy lately. I'll get you some soon.Ben90 wrote:I was about to mention the set that came up recently, you must have had them!Got any pics of them on the car?
In the mean time you can check this link for Dune wheels on a GTI
http://www.uk-polos.net/view ... 41#p453041
Re: new to forum
those wheels look amazing!! i wouldnt want my car that low even though it looks immense anyone know how muchits been dropped?
Re: new to forum
why does everyone on here go for 007p? is there a reason? also whats the score with the different colour springs
cheers
cheers
- Ben90
Re: new to forum
It's just an all-round good upgrade diverter valve for the 1.8t engine, made by Forge who make a load more decent engine bits. It recirculates air rather than venting to atmosphere so you don't get a chavvy loud TSSHHH but a quieter one that recirculates the air to keep the engine happy while doing its job.
The springs depend on the boost pressure you're running. I believe after a stage one some people uprate their spring, pretty sure green is the standard one Forge send and will do fine even on remapped Gtis, others go for the yellow one after a remap. It's just down to whether you start to lose boost when you punt it, if it surges, stick a yellow one in
or a spacer that comes with the spring kit.
Re: new to forum
okay thanks thats big help is it a worth while mod? im guessing it shaprens up throttle resonse and helps not loose boost?Ben90 wrote:It's just an all-round good upgrade diverter valve for the 1.8t engine, made by Forge who make a load more decent engine bits. It recirculates air rather than venting to atmosphere so you don't get a chavvy loud TSSHHH but a quieter one that recirculates the air to keep the engine happy while doing its job.
The springs depend on the boost pressure you're running. I believe after a stage one some people uprate their spring, pretty sure green is the standard one Forge send and will do fine even on remapped Gtis, others go for the yellow one after a remap. It's just down to whether you start to lose boost when you punt it, if it surges, stick a yellow one inor a spacer that comes with the spring kit.
- Ben90
Re: new to forum
Not sure mate, no first hand experience here just repeating what I've read. Technically it stops the turbo stalling when the throttle valve closes between shifts, minimizing the turbo lag straight after the gear change while the turbo spools up again. I believe the Gti is fitted with a diverter as standard, but the 007p performs much better.
Re: new to forum
Anyone know best tyre size for dunes? Not keen on stretch. Think their 215 40 but will that be too with for 9n3?
Re: new to forum
jeremie wrote:Anyone know best tyre size for dunes? Not keen on stretch. Think their 215 40 but will that be too with for 9n3?
If you don't want a stretch then you'll be best off going for 205/40/17. Though, i'd go for 195's as you'll need it if you want to go low.
Re: new to forum
is 215 still too wide even if i dont plan on lowering?
Re: new to forum
new jvc HU really pleased with it
