Induction Kit
Induction Kit
i know i've asked this before people but i really need some help as to what filter and elbow bends etc to buy i have emailed badger 5 several times and he hasn't replied. And can any bulb specialist recommend a good side light bulb a nice crisp white one?? Thanks
polochris1
Re: Induction Kit
Hi mate, you'll need a 70mm diameter silicone elbow, 90 degree if you want it to sit in the bottom half of the airbox and a 70mm outside diameter air filter of your choice plus two 60-80mm hose clips to hold it all together. This arrangement will then bolt directly to the MAF sensor piping.
Re: Induction Kit
Sound as mate for this info. is there a benefit of having the filter in the bottom half of the airbox? Any links aswell please?
polochris1
Re: Induction Kit
no worries mate, well it will reduce heatsoak slightly and the original air feed will provide it with some cool air.
This is the sort of thing you want as far as the pipe goes http://www.jsperformance.co.uk/silicone ... -bend.html
Then any 70mm cone filter would do - e.g https://www.jetex.co.uk/jetex/store/ind ... uctId=6691
You'll also need a 28mm breather filter for the SAI pipe - pipercross do one that fits perfectly, bought it direct from Forge as i live close.
Re: Induction Kit
Spot on chief thanks alot
Re: Induction Kit
do you have a link to the filter you put on the SAI please?
polochris1
Re: Induction Kit
I don't have a link as i bought it directly from Forge up in Gloucester sorry mate.
I would ring them and check but if you buy this http://www.forgemotorsport.co.uk/conten ... ct=FMFIL28 I think they will send the pipercross one out that they sold me.
Re: Induction Kit
that will do me! been hunting for something like this a while, cheers for the help, when payday comes i can get one ordered and take out the tights in the sai
polochris1
Re: Induction Kit
No problem dude, you helped with the idea of this setup in the first place
How do you find it by the way? because I don't get any intake roar with the ITG cone the way it is now, its like the engine is too loud to hear it. Just wondering weather a cone filter like the jetex one above might be louder.
Also just checked the packaging for the pipercross filter I have and it's a motorcycle filter if that helps
Re: Induction Kit
I like it, i do get alot more noise over the pannel filter,it does roar for me anyways and i get the noise from the 007 which is nice too
Re: Induction Kit
Got my stuff in today the filter, silicone hose and the sai filter the one from forge is a pipercross one! Also i noticed i'll need to buff down either the hose or the filter neck since both are 70mm x 70mm im guessing this is just a case of peeling off some rubber?!
Re: Induction Kit
my pipe was a 70mm pipe and the maf housing went straight in no problem, the filter took a bit of persuaion but it all went in eventually!
Re: Induction Kit
I've just got a k&n panel filter at the moment...revo stage 2 with FMIC 007p etc
Was looking to get either an open cone, with some sort of cold air feed/ducting and a heat shield.
Saw this on awesome's site:
http://www.awesomegti.com/car/vw/polo9n ... vag-ib-18t
anyone used these? Are they worth the money over the likes of a K&N cone filter kit?
Re: Induction Kit
bump
