1.6 in Mk3
geezer222
1.6 in Mk3
Post by geezer222 »
I have read some where that its possible to fit a 1.6 polo MK4 engine into a Mk3 has anyone done it or is it possible ? Cause for the life of me I can't find that mag i read it in . Or am I going INSANE
Gareth_GT_Hatch
Post by Gareth_GT_Hatch »
It depends what you want to do. The engine does; fit theres one less bolt hole for the engine mount thats actually on the engine. (the other two are on the gearbox) So theres two bolts instead of three. Which is ok.
If you do everything; loom ecu and all the wiring then thats the best way. What I was trying to do was run a 1.4 litre mk4 engine with GT running gear so I could in theory have about 80bhp before I do any proper mods. This isnt so easy as I found out as 1 thing from the entire engine is incompatible (the inlet manifold). So Ive tried and to some extent failed to use the GT head on the mk4 polo block. This doesnt work because the design of the combustion chamber is different. A couple of diesel headgaskets would have sorted this but ECP have taken a month so far and theyve still only managed to get one (need 2).
Anyway what I should have done was bought a Golf 1.4 (not 1.6 as it has same problem as 1.4 mk4 polo) single point injection engine and used all my GT bits on that because the two engines (GT and 1.4 golf) are identical. Even the headgaskets are the same part number! I will be doing this in the near future probably so watch this space!
Krupa
Post by Krupa »
It's an old issue of PVW you want, two silver Polos a Mk4 (DanDan off Porka.net used to own that one) and a Mk3.
From what I can remember it had a 1.6 Golf engine, but had GT injection and engine management. Was in the G40 power range from what I can remember.
hayesey
Post by hayesey »
yeah I remember that. you're talking about 2 years old now though.
could you not use the earlier mk4 1.6 engine?
Gareth_GT_Hatch
I think ive heard of this one. Did he have the throttle body bodged onto the 1.6's inlet manifold? Icould have done that myself but I wasnt too keen on the 1.4 polos cylinder head (teeny tiny inlet + exhaust ports)
geezer222
Found it Now
Post by geezer222 »
Thank for the info , as i have just bought the car but the engine if no good and thought i may as well do the convertion now rather than later and buy two engines and waste money , Ive also got a jetta 1.3 that i am putting a 1.8 in that so the 1.3 is spare and it only done 47000 mile , i have been told they are different and have no clue if the are or not .
Gareth_GT_Hatch
The AEA has the same setup as the AEE in terms of the combustion chamber being split between the head and the block. It has a different part number to the AEE and AEX engine in terms of inlet manifold gasket but neither of these are the same as a GT whereas the 1.4 golf one is).
What setup have u got now on the polo? GT or CL or what?
geezer222
Post by geezer222 »
Its 1.3 cl coupe M reg , can only tell you that as its at a mates garage and he gone on his hols .
polog40racer
Post by polog40racer »
I remember that 1.6 engined mk3.
Frode gave me the same advice when I had my GT as how the guy did it. Struggling to remember now, but it was using an old 1.6 block from a Passet or something similar. You had to machine the head carefully to get the piston to valve clearance just right. Frode friend had done this conversion but he buggered it up as he was using a head that he had already skimmed before and it was skimmed too much so the engine din't work well. Done properly on TB's, solid lifters (for 8000rpm), Frode was saying figures of 180bhp!
geezer222
Post by geezer222 »
:shock: Ive found it in ( The Golf DEC 2002) it says you can fit a 030 small block 1.6 engine from a 1994 polo its got the same power as the polo GT 75 BHP , it says it effortless to fit and it can be tweaked to 100 BHP plus it torquier than the Gt . Now all i need is the engine - has any one got one for sale ?
Gareth_GT_Hatch
Yeah if you can get one get an AEE as its more tunable (muti-point injection) You are just gonna have to ring breakers yards for engines I think.
Tahrey1043
Post by Tahrey1043 »
geezer222 wrote: it can be tweaked to 100 BHP plus it torquier than the Gt
At 1600 vs 1300cc but with the same output I should damn well hope so! :lol: That 100hp probably comes from restoring the shape of the torque curve closer to that of the GT (ie a whole lot flatter towards the top :)).... tho if it makes it pokier thru the whole rev range that's nice too of course!
geezer222
Post by geezer222 »
Gareth_GT_Hatch wrote:Yeah if you can get one .
You seem to know alot about codes for engines the 030 what is the code for it as the scrap yards are asking me for it ?
Gareth_GT_Hatch
Its difficult to give you the vw part number as an engine isnt classed as a single component. If you ring vw specialist breakers theyll know what you mean when you say AEA, AEE or whatever. Look ont yellow pages (www.yell.com) Ive just had a look for you anyway and i think its 032 100 103 CX but im not 100%
geezer222
Thankyou
Post by geezer222 »
Thankyou to everyone how has help on this question
From geezer222
