01276 - ABS Hydraulic Pump (V64): Signal Outside Speci
6n2stan
Drives: 6N2 GTI, Golf GTD + R32, T5.1 BiTDI DSG
Post by 6n2stan »
I had an ABS light come on on the way back from Ed38. I got home, switched off and unloaded the car etc and when I started it later on the light cleared as normal. Today no light either.
I've plugged into VAGCOM tonight and got the above code. Is this the dry solder joint that I've heard about before in the ABS ECU? Does it start intermittently before packing up all together?
I've cleared the fault down and it hasn't come back (tonight). I hope it stays off until at least next Tuesday when it's due it's MOT. I've usually MOT'd it by now but I didn't want to risk a failure before this weekend :?
alexperkins
Site Admin
Re: 01276 - ABS Hydraulic Pump (V64): Signal Outside Speci
Post by alexperkins »
Yes that's a sign it needs to be repaired
Follow the guide here
http://www.uk-polos.net/view ... 10&t=58585
6n2stan
Post by 6n2stan »
Bugger! ah well.
So I assume taking the module off (to repair) and running the car without it with the ABS light on is technically OK?
joe2612
Location: Guildford, Surrey, Drives: Polo GTI 6n2 Black
Post by joe2612 »
Running the car like that is technically OK, just be wary in the wet as you don't have ABS!
It's a module off jobby yes, careful removing the four gold star headed bolts that hold it on. They are very easy to round off so ensure you've got your ratchet on at the right angle and with firm pressure.
6n2stan
Post by 6n2stan »
Cheers, I'll get it through its MOT first before I do the job anyway.
My first 4 cars didn't have ABS, back to the old skool lol
Sent from my iPhone using Tapatalk - now Free
alexperkins
Site Admin
If the ABS light is on/comes on during the mot it'll be an instant fail
6n2stan
Post by 6n2stan »
alexperkins wrote:If the ABS light is on/comes on during the mot it'll be an instant fail
It's still off since it cleared on Sunday night, I'm taking my laptop to the MOT just in case....
Sent from my iPad using Tapatalk - now Free
hallie123
Post by hallie123 »
Definatly sounds like the soldered joint has cracked, done mine a couple of weeks ago following alex's guide, repaired it and had it all back together within an hour, no problems scince! i'd do it before your MOT too its sods law the light will come on half way through and cost you another MOT :)
6n2stan
Post by 6n2stan »
hallie123 wrote:Definatly sounds like the soldered joint has cracked, done mine a couple of weeks ago following alex's guide, repaired it and had it all back together within an hour, no problems scince! i'd do it before your MOT too its sods law the light will come on half way through and cost you another MOT :)
If only I had time before next Tuesday Hallie, as long as I get the car back within the week, its a free re-test :)
Oskah
Post by Oskah »
Mines been doing this for a while now, I didnt realise you could still drive the car with the module removed so I have been putting it off until I have a few days free, might just get me arse into gear now and pull it off and have a go at sorting it out
alexperkins
Site Admin
To be fair, you shouldnt drive the car with the ABS module removed as it can pull dust into the ABS pump housing as its a sealed unit when the module is attached.
6n2stan
Post by 6n2stan »
Yeah, I'd polly bag the ABS pump up if I took the car out a lot.
Oskah
Post by Oskah »
Well I did mine today in my Dinner hour and it is a pretty easy job to do in fact the hardest thing for me was getting hold of a E5 torx bit. The casing was a faff as it took time but the seam is pretty to follow with a hack saw.
I drove home tonight and its been the first time in ages that the light didnt come on, hopefully thats the end of it now
