Cheers pal!ryanday91 wrote:Very smart Absolutly love the wheels! real good to see someone do something different
The plugs are NGK BKR7E. They seem to be the most common one people use after doing a bit of research.lukey GTI wrote:What plugs did you use and how did you do the SAI delete ? Glad to see you keeping it
Sent using tapatalk
http://www.seatcupra.net/forums/showthread.php?t=200030 Is a link to the guide I used for the SAI, N249 and N112 delete. I bought the resistor kit off ebay along with the forge blanking plate. Wasn't too hard to do, got it done in a night after work. Only trouble I had was removing the tower the combi valve sits on requires removal of a coolant pipe which i wanted to avoid. I had to alter the blanking plate a bit so that it would sit on top of the tower directly in place of the combi valve.
