GTI 6R Rear Defusser
robertsm66
Drives: VW 1.2 TSI
Post by robertsm66 »
Hi
Does anyone know if the rear defusser off the GTI will fit on the Rline bumper or can be modified to fit. Both vehicles seem to have similar rear grey plastic defusers however I'm guessing the exhaust hole / gap on the GTI one is slightly wider. Positioning looks exactly the same.
Rob
Re: GTI 6R Rear Defusser
It's not interchangeable unfortunately
robertsm66
Drives: VW 1.2 TSI
Have you tried ? I don't fancy butching my Rline defuser to get a double outlet in but it may be the only way.
tried the other way around (r-line diffuser on GTI bumper)
robertsm66
Drives: VW 1.2 TSI
Ah, so what didn't fit, wrong size or was it the fixings ?
both :p
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
Buy a complete GTI bumper. It also looks much better than the R-Line one.
Never liked the glued on piece at the buttom on the R-Line rear bumper... Makes it look like an aftermarket cheap "GTI look" kit.
robertsm66
Drives: VW 1.2 TSI
I think it's down to personal tastes on bumpers, valances and diffusers.
I've got an Rline bumper on my 1.2TSI SEL. I really like it actually in comparisson to the standard bumper. The diffuser clips / screws on and is good VW quality. Not sure one you've seen that glues on and certainly isn't cheap as I bought mine new.
I'm like both the GTI and Rline rear end, I just want an OEM look exhaust outlet hole rather than a customised look.
greypolo9n3
Drives: white 6r 1.6 tdi rline/gti
Post by greypolo9n3 »
I got an r line rear bumper and also put a gti exhaust box/tips on it, so ive had to cut out space on the existing diffuser.
Its easily done if your good with your hands!
robertsm66
Drives: VW 1.2 TSI
So, you just modified the existing diffuser ?
Did the GTI back box use the same fixing points as the standard exhaust or did you have to modify anything ?
greypolo9n3
robertsm66 wrote:So, you just modified the existing diffuser ?
Yeah the existing diffuser had space for one exhaust...i just cut it up to make room for twin tip
Yepp exactly same fixing points
only difference is...with the gti bumper the exhaust would sit flush....with an R line bumper the exhaust sits a little bit back..but i like that its more discreet and not in your face
