It does look a bit familiar
Installed on a Polo with BlueMotion Technology?iichel wrote:It does look a bit familiar
On Sunday...news about HBA.
I think the photo is from the old Polo Bluemotion 1.2TDI. But my current 1.4TSI Blue GT (with bluemotion technologies) has one too.
hi ciclo
you have an email on gmail
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
gmail is also an email...wamba wrote:hi ciclo
hmthakur
- Drives: Polo gt tsi 1.2 dsg
Hi ciclo i own a 2015 1.2 gt tsi in India . Chasis number is mexc15608ft079060
Engine number cbzj45870. I want to fit steering wheel with paddle shift. Can you help me with part number and source for the part. thnks
Thank you for such good information, when I finished with the project I'm doing I will have to study this information carefully.wamba wrote:hi ciclo
Hi hmthakur, Welcome.hmthakur wrote:Hi ciclo i own a 2015 1.2 gt tsi in India . Chasis number is mexc15608ft079060
Please read here: http://www.uk-polos.net/view ... 05#p498936
Thank you for your understanding.
Loading information about the project ...
Remembering
BCM & Stalks
BCM
Stalks for my R-line with MFSW
These stalks are for them to work in this way
To install these stalks on 6R (original factory xenon or BlueMotion only) have to make some changes in the wiring of automatic lights, also in the original wiring. It's simple, though in the following diagrams may seem some complicated.
Do you remember this diagram?
Click here to enlarge
https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Now to install new stalks it should be as follows
For example, if you already have the automatic light wiring, this is the change that you must make in the wiring.
Also add the necessary wires according to the pinout assignment of diagram.
I just wanted to mention that to carry out this diagram it took me a many hours of work and research.
As I mentioned earlier I do not have the necessary diagrams from Elsawin.
Test 2 in the following post.
BCM & Stalks
BCM
Cool stuff going on there ciclo. Respect for you creativity and perseverence. Excellent work.
Thanks iichel increasingly closer to get it.
Info about Test 1
http://www.uk-polos.net/viewtopic.php?f ... 10#p499679
Autoscan http://www.uk-polos.net/viewtopic.php?f ... 10#p499786
Test 2 (in the right direction)
Once the new stalks wiring is installed correctly, "the lights" all lights have to be coded again. The real problem is that it must be done without VCDS label, also without documented Adaptation channels.
On the other hand I installed the communication network (CAN) of camera in the right place, as follows:
This diagram is applicable for know how to install this type BCM 7E0 Max4 on a 6R. (CAN line from instrument cluster to bcm)
After a small study
of the coding of this BCM on a T6, thanks to this publication, and after two grueling hours playing with Bytes and binaries, achievement that all lights work properly, as before, but I can not achieve that the high beam remains fixed by push the stalk.
Also, as I deactivated HBA after the Test 1 when I plugged VCDS cable for Test 2 the Gateway showed a fault about coding for HBA, when HBA was activated on Installation List no faults in the Gateway...
Anyway I do not get activate the HBA, perhaps the adaptation or coding are required at another Address.
Autoscan:
Note: Results are identical with TP 1.6 or TP 2.0 (Byte24 Bit4)
Info about Test 1
After a small study
Autoscan:
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 10 15 17 19 20 25 2E 37 44 55 56 77
VIN: WVWZZZ6RZDY0CICLO
20-High Beam Assist. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 2686
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F 004004
ROD: N/A
VCID: 6AD1DAE88D81284E2A7-803F
No ASAM data for: "EV_ECM12TFS02103F" (VW25)
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
VCID: 8201124819F1500E027-80D7
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 387530A08BAD4ADE6C3-806D
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
Revision: B9080001 Serial number: 0771 100150209
Coding: 3CB02FBF08E1240093380ED16EEB8FD0FAC067FF600D30D0320000030800
Shop #: WSC 18752 008 00032
VCID: E8D520E01B8D9A5EBC3-80BD
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 050512 05 54 0403
Coding: 1F302D
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF
Component: J387__TSG_BT 003 8612
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361212601014
Coding: 308001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E7926B8A18974EEA6F-806B
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4A917A68ED41C84E0A7-801F
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405N1C4LI7929
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB405B1D5MS8GS2
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB405B17ABS901.
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB405B181TUDPKC
Part No SW: 6R0 920 870 C HW: 6R0 920 870 C
Component: KOMBI H05 0607
Coding: 140E01
Shop #: WSC 00233 572 91226
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 356B399494BFB7B6775-8060
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0733
Revision: B9080001
Coding: 002200
Address 20: High Beam Assist.
Cannot be reached
Component: IMMO H05 0607
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EAD15AE80D81A84EAA7-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
VCID: 2A511AE84501E84EEA7-807F
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5218
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
Shop #: WSC 12345 123 12345
VCID: 3777339C86B345A6659-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V9 7918
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F670BFCEAE38D663D9-807A
Address 55: Xenon Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
ROD: EV_HeadlRegulVWLWRPt.rod
VCID: F7F7739C4E3305A6259-80A2
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3B7F2FACB29B61C6811-806E
End ---------------------------------------------------------------------
Re:BCM compatibility query
Hi
I want to upgrade my POLO's BCM (6RU 937 086 D) to a suitable one that supports cruise control.
I see many BCM versions are available online for sale but cant determine whether the new BCM will work or not.
How/where to check higher versions of BCM which are compatible with my car?
E.g. I found 18D 937 087 F BCM but how to check its compatibility?
Strayion
Strayion
In a scirocco the camera is connected to the powertrain CAN bus... (same as the airbag module). That did'nt work or?ciclo wrote:On the other hand I installed the communication network (CAN) of camera in the right place, as follows:
Re: Re:BCM compatibility query
http://www.uk-polos.net/view ... 96#p499996Strayion wrote:Hi I want to upgrade my POLO's BCM (6RU 937 086 D) to a suitable one that supports cruise control.
Thanks Strayion
Please Strayion http://www.uk-polos.net/view ... 05#p498936
The camera retrofit in Golf 6 is usually suggested to be connected on the automatic headlight range module (German forums mostly).
That is also the powertrain canbus but not every powertrain canbus is the same with the new BCM
... and many other Volkswagen models, but in this case is exactly as shown in the diagram, You can be sure.diskoboy wrote:In a scirocco the camera is connected to the powertrain CAN bus... (same as the airbag module). That did'nt work or?ciclo wrote:On the other hand I installed the communication network (CAN) of camera in the right place, as follows:
Autoscan from Test 2 is much better than Autoscan from Test 1
keep in mind that it is necessary to combine different Bits from different Bytes, doing a simple calculation of possible combinations is difficult to hit the right combination, but with some knowledges and lucky to have the Autoscan T6 the posibilities of succeeding increase exponentially.
... the other day (Test 2) it was a great success achieve that all lights are working properly again, with Stalks-wiring new, without any type information (BCM labels).
Very probably the two things that I have left to achieve are very closely related.
Solution? I'm still working on it...
