Newbie, maunual clutch cable conversion-Arosa
Re: Newbie, maunual clutch cable conversion-Arosa
3l,,,wow, the 106 is 2l
I don't think I've got a 17mm hex either.
Does it need to be drained?
Does oil pour out of the drive shaft holes?
Drained through the drain plug fill throughout the fill plug
What happens if you don't drain it? does it end up all over the floor?
For changing the clutch you don't have to drain it at all
That can be done with the gearbox full
Is this the correct spline bit? M8?
http://www.ebay.co.uk/itm/281324520461
or
http://www.ebay.co.uk/itm/321179925405
long or short?
or
long or short?
Long. It's an utter PITA otherwise
That's what I thought.
Is there a gasket behind the D/S flange that needs renewing?
Not unless it's leaking
Gearbox out, not too hard.
Stuck with release slide screws, what size spline drive?
Release slide screws? Can you be more specific
3 screws holding release bearing slide/sleeve/tube.
Spline drive smaller than the M8 on the Inner CV's
Oh those, I think its M6, though it might be M7 according to the listing
Just phoned my local factors, none of his sets include M7 so hope it's M6
Also, how do extract the selector shaft seal? Dig it out with screwdrivers?
You can use an allen head failing it not being an M6..its been a while since ive changed one of those
Yes, or with like a dentist pick
Youll need to be careful removing it as you dont want to scratch the housing or the shaft
Refitting your best to use a deep socket over the selector shaft and tap the end with a mallet to seat it nicely.
I tried an Allen on one last night, it slipped. Pretty sure that was a 6mm if that means anything.
I've got a decent size braddle point I could lever over something, how tight are they?
