£50 because I got it done off a proper wrapping company, they tried Matt black wrap too but it didn't look as goodjacksb7 wrote:How much did that set you back?Karlcee wrote:
Well this happened today. Might not be to everyone's taste, but the world would be a boring place if we were all the same. I personally love it, completely changes the look of the front of the car. (sorry its a quick I phone pic haha)
I will be testing this esp to see if it flashes on another note
New GTI
Re: New GTI
blackertracker
- Drives: ..
Re: New GTI
Thanks for that duffman!duffman wrote:Here you go (fyi you press Menu then scroll to set up)blackertracker wrote:Could anyone with the App Connect option (Apple CarPlay & Android Auto) please tell me what hardware version your headunit is please?
I think you find this out by pressing the Car button, then going to Settings and System Information/Version.
Thanks.
lewisp
- Drives: Polo GTI
Re: New GTI
Got a wee bit excited over this!
https://video.citnow.com/vt9-6-rR2f6
Dink
- Platinum Member
- Drives: 2015 GTI
Re: New GTI
Anyone know what size torx driver you need for the screw the remove the end of the key
It looks really small and I've seen a set in halfords but only goes down to T5 and don't want them not to fit
CJO
- Drives: VW Polo GTi 2016
Re: New GTI
Not excited at all then!lewisp wrote:Got a wee bit excited over this!
nats148
- Drives: 2015 1.8 GTI - Golf Anniversary
Re: New GTI
Think I read further up it was like a jeweller's one they had to use?Dink wrote:Anyone know what size torx driver you need for the screw the remove the end of the key
Dink
- Platinum Member
- Drives: 2015 GTI
Re: New GTI
Can't see anywhere that says the actual size.
I just don't want to get a T5 for it to be a T4 size.
- m0rrthal
- Drives: 2015 VW Polo 6C GTI
Re: New GTI
I had a really strange issue today. During my way to work, just while I was driving in a straight line, an "Your rear left door are open" indicator showed up
I pulled over and it really wasn't completely closed
The last time I was opening this door was on Monday and since then I was using the car several times...
CJO
Re: New GTI
Sounds like it was closed enough not to set the sensor off and then the general bumps from our beautifully maintained roads here in the UK finally caused it to open enough to set the sensor off.
Norfolk Boy
- Drives: Polo Gti
Re: New GTI
I'm thinking about adding the Car Net App Connect facility which my dealer quoted as £170 as a software upgrade. I know in hindsight it would have cost £100 to have it fitted in the first place but at the time I really didn't get an explanation of what it could do apart from being told Mirrorlink didn't work. Main reason is to display the iPhone sat nav on the display in the car. Grateful on views on whether this is worth doing and I think I could then use Siri to access phone contact etc?
CJO
Re: New GTI
In regards to Siri if you just use your mute button and say "Hey Siri" it should initiate the familiar blip over the Bluetooth anyway. Certainly did in the Golf mk6.
CJO
Re: New GTI
I'll happily do a review when my car arrives
Willoughbyyy
- Drives: Scirocco R 2015
Re: New GTI
Finally the tracker updated to 'build in progress' although the dealer told me it started on the 4th! they have also told me i'll have it by the end of the month
Does end of the month sound realistic? i think they are just pulling my leg because i told them i'll be canceling if it takes much longer..
Norfolk Boy
- Drives: Polo Gti
Re: New GTI
CJO wrote:In regards to Siri if you just use your mute button and say "Hey Siri" it should initiate the familiar blip over the Bluetooth anyway. Certainly did in the Golf mk6.
Thanks I will try this.
CJO
Re: New GTI
I should add that for the initial "hey Siri" your phone mic needs to hear you. Hence the mute. After that it should connect over Bluetooth.
