Just started my sons car and let it warm up to normal when the engine management light came on. Luckily I bought a code reader from Ebay and that gave me a code of P0141.....................
02 sensor heater circuit (bank 1 sensor 2).
Can someone please tell me what this is and where it is located?
I have only just replaced the thermostat and (green) heater sensor.
fault code P0141
- Adriandiamond
- Drives: Financing sons Polo 1.4 2001 (6N2)
Re: fault code P0141
Thats on the lambda sensor. Bank 1 is in the exhaust manifold on the front of the engine.
Its very common for the wiring to break down on these where they meet the plug on the gearbox
- Adriandiamond
Hi Alex. I'm probably totally wrong but wouldn't that be bank 1 sensor 1? I had an idea that sensor 2 was on the exhaust somewhere????alexperkins wrote:Thats on the lambda sensor. Bank 1 is in the exhaust manifold on the front of the engine.
I read sensor 1
. yes sensor 2 is in the exhaust after the cat
- Adriandiamond
Great thanks. I'll have to wait till we get a decent dry day before crawling about on the floor. I'll get back to you with the result.alexperkins wrote:I read sensor 1. yes sensor 2 is in the exhaust after the cat
Cheers again.
- Adriandiamond
Can someone please confirm that this is the right connector for "bank1 sensor2".......I think it is but just want to make sure.
That's bank1 sensor 1. Wiring for sensor 2 is underneath. Follow the sensor wiring from after the cat
- Adriandiamond
Cheers Alex. As they are both together thought I might as well check them both out. Disconnected both plugs, blew out any dust with compressor, sprayed inside both plugs and sockets with WD 40 and reconnected.alexperkins wrote:That's bank1 sensor 1. Wiring for sensor 2 is underneath. Follow the sensor wiring from after the cat
Removed fault code and restarted engine..............EM light is now flashing and when I tested for which fault code, it is now coming up with
Took out plug 3 and ran engine......it ran the same as with plug in, a bit ropey. Replaced plug, removed fault code and started the engine..........No EM light and no fault codes.
Engine now runs like it should.
Happy days
- Adriandiamond
Happy Day (minus the "s") cos the gremlins will be out again tonight removing bits and creating even more fault codes. I've actually seen them do italexperkins wrote:Happy days
