Solid/Vented discs 1.0 Lupo(Arosa)
piglet14
Drives: Arosa
Post by piglet14 »
There seems to be a choice of vented or solid on the fronts of the Arouser.
The vented discs are 18mm thick & the solids 10mm.
Will both options go in the calipers with new pads?
Current fitment is solid, just fancy a techy upgrade.
Ta
alexperkins
Site Admin
Re: Solid/Vented discs 1.0 Lupo(Arosa)
Post by alexperkins »
For a 1.0, i wouldnt be that bothered. The brakes are piddly anyway
18mm vs 10mm is a massive difference too
Stick with solids in my opinion.
piglet14
Drives: Arosa
Post by piglet14 »
Piddly and they fade.
alexperkins
Site Admin
Fresh brake fluid and new discs and pads should improve it ten fold. My 1.0 6n2 polo brakes were good enough to stop if needed
Check the condition of the rear shoes too
What's the reg? I'll check out the original spec it should have brake wise
piglet14
Drives: Arosa
Post by piglet14 »
removed
alexperkins
Site Admin
239x10mm is the spec for yours.
The 18mm is for the 1.4 upwards
piglet14
Drives: Arosa
Post by piglet14 »
ECP list a 239 x 18 vented for the 1.0
Part VAG-6N0615301C
Are the calipers the same for the 1.0 & 1.4?
alexperkins
Site Admin
Don't always trust what ECP says is compatible - it's often wrong
The 16V 1.4 has larger brakes - normally 256mm but it might be 239 on the arosa
alexperkins
Site Admin
239x18 are for ANW,AKK,AUD, AKU engines
239x10mm are for AER,ALL,AHT, ALD,ANV,AUC engines
piglet14
Drives: Arosa
Post by piglet14 »
Yep, 18mm vented don't fit.
The 10mm solid discs were down to 6mm in the middle, nice.
